RV.Net Open Roads Forum: Truck Campers: Furnace on while moving
 > Furnace on while moving
Nevrdun
Smethport, PA
Posted: 02/22/23 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
We are traveling in cooler weather and I am wondering if I can run furnace at the lowest setting while on the road? Assuming adequate power to run the fan and propane supply.
Thank you.
May I become the person my dog thinks I am
KD4UPL
Swoope, VA
Posted: 02/22/23 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
Of course. No reason not to. It's done all the time.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 02/22/23 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Run the furnace, air conditioner(s) refrigerator and water heater while moving if you want.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Buzzcut1
Norcal
Posted: 02/22/23 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
go right ahead. just remember to stop short of gas stations and turn off the furnace and the fridge before pulling in to fuel then remember to turn them back on after you leave the pump area
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
jimh406
Western MT
Posted: 02/22/23 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I guess it's possible, but I wouldn't. Considering fridges blow out, I would expect the furnace to blow out.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
notsobigjoe
southeast
Posted: 02/22/23 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
Been running with fridge and heat on for years. Never a problem. Fridge is run on 12 volt and heat is ignited by a glow plug. If I may suggest putting all of your bedding in the overhead stuffed up against the front wall to use to better insulate. And definitely use the overhead vent insulation of your choice.
I have never run the temp above the lowest setting of 50 degrees.
BarabooBob
Baraboo, WI
Posted: 02/22/23 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I have pulled my TT many thousands of miles and I have never had the fridge blow out. My furnace has never blown out in 60 mph winds so why would it while driving? The thermocouple would shut the gas off if the furnace stopped working properly.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
camper19709
middletown,DE
Posted: 02/22/23 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Yes Yes and Yes
I do it all the time with no blowouts
Just remember to turn off the propane while fueling up.
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
04 Chevy Astro van toad
deltabravo
Spokane, WA
Posted: 02/22/23 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
I run mine, but not at the "lowest" setting.
I set it to about 60 degrees or so.
About an hour before I reach my destination, I turn it up warmer with the bluetooth t-stat I installed a few years ago. THe vieo shows it in a travel trailer I had for a short time. I moved the t-stat to my AF992.
stevenal
Newport, OR, USA
Posted: 02/22/23 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
When traveling in sub-freezing temperature, the heat stays on low to prevent frozen pipes and doggies. No problems yet.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
