RV.Net Open Roads Forum: General RVing Issues: Propane hose pigtail replacement
 > Propane hose pigtail replacement
jo-e90
campground
Posted: 02/23/23 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone found a reliable quality replacement or different idea in place of the cheap Chinese propane pigtail hoses and plastic acme adapter that does not leak right away or 6 months to a year?
Makes you wonder how many actually water spray test their hoses before each outing.
I think most would be surprised how many leaks are unknown.
* This post was edited 02/23/23 02:26pm by jo-e90 *
JimK-NY
NY
Posted: 02/23/23 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
First that "plastic acme adapter" is not designed to form a seal and does not need anything more than gentle hand tightening. The seal is formed between the brass fittings inside the adapter and inside the propane tank. It takes a lot of excessive force and probably use of a wrench to break one.
The hose is a different issue. The problem is the deterioration of the hose due to exposure to propane. This includes drying out and becoming brittle. Another issue is that the deterioration can result in an oily sludge making its way to the regulator. This is not a quality issue but more an issue with the standard materials being used regardless of country of origin. I have been replacing my hoses approximately every 5 years due to becoming stiff and potentially cracking especially in cold weather. I am now trying a "non-leaching" propane pig tail. It is a little more expensive but should last longer. Several companies sell this. Mine is from Marshall Excelsior.
agesilaus
North Florida
Posted: 02/23/23 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Amazon Propane pigtails
You have plenty to pick from, maybe you can find some made in the USA
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
time2roll
Posted: 02/23/23 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Get the Cavagna brand for a superior crimp and quality rubber hose.
Verify if you need the inverted-flare or 1/4 pipe thread before you click and buy.
Get the right length too.
https://www.amazon.com/Cavagna-190-0032-Acme-Pigtail-Hangtag/dp/B00FFAZCFS
675w Solar pictures back up
CharlesinGA
South of Atlanta, Georgia
Posted: 02/23/23 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
Marshall Excelsior is made in the US. Everything.
Here is their camp and RV catalog. https://www.marshallexcelsior.com/sites/........ault/files/2021%20MEC%20RV%20Catalog.pdf
Very useful catalog with lots of information. For pigtails, you need to decide how long, braided metal jacket or not, and 1/4 pipe thread or 1/4 reverse flare.
Get the part numbers and go searching on Amazon or elsewhere and see what you find.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
deadticket8
All over
Posted: 02/24/23 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Just replaced cheap leaking hoses on a Winnebego (super cheapo lighting too) with Marshalls.Also the regulator was leaking. Always had good results but I am just getting back after 7 years. Scary part was all the hoses leaked and you could smell it inside the unit. What was the last owner thinking?
rhagfo
Portland, OR
Posted: 02/24/23 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have taken old one to propane distributor with service department and had them made. Didn’t cost any more and the hose seems to stay flexible much longer.
C Schomer
Pueblo West, Co.
Posted: 02/25/23 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have new pigtails made with rubber hose at Gas Equipment in Denver.
deltabravo
Spokane, WA
Posted: 02/25/23 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Marshall Excelsior.
I installed longer pigtails on my truck camper not long after I got it in 2020. Last year one of them started leaking. I replaced it and now keep a spare on hand.
Sometimes even the good ones leak.
