RV.Net Open Roads Forum: Tech Issues: Kitchen stove fan "flap".
 > Kitchen stove fan "flap".
bighatnohorse
Cave Creek
Posted: 02/24/23 07:21am Link  |  Quote  |  Print  |  Notify Moderator
The plastic hinge pin is what broke on mine. I fixed it by purchasing a 1/8-inch diameter carbon fiber rod from a hobby store.
I epoxied the rod to the length of the flapper edge in such a way that it replaced the hinge pin.
The flapper never came off after that.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
wnjj
Cornelius, Oregon
Posted: 02/24/23 11:21am Link  |  Quote  |  Print  |  Notify Moderator
14 gauge Romex works perfectly. Just pull the white wire from the bundle. Then glue it along the rib at the edge and stick about 1/4” - 3/8” past the end. You can even bend it slightly to install and it will straighten as you push up on the flap. Ours has been that way for 10 years.
Found a picture:
* This post was last edited 02/24/23 01:37pm by wnjj *   View edit history
bukhrn
Lanexa, Va
Posted: 02/24/23 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
I went through 2 of those plastic pieces of **** before I found this, it's made of aluminum, I doubt the little tabs will fall off, a little pricey, but worth it. https://www.amazon.com/FUSION-Sports-Pro........471801a&psc=1&ref_=pd_bap_d_csi_day0_0_t
2007 Forester 2941DS
2014 Ford Focus
ICamel
Oregon
Posted: 02/24/23 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
JimK-NY wrote:
I repaired the replacement by using a piece of coat hanger as a substitute for the plastic hinge piece.
That worked for me also. Put a piece of white duck tape to hold the straight piece of wire coat hanger in place, and then epoxy to make the fix permanent.
The suggestions for a wire rod and Romex are also great ideas!
Cheers!
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
deltabravo
Spokane, WA
Posted: 02/24/23 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
While on the subject of stove hoods, I found this mystery lever on my stove hood.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 02/24/23 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
I also repaired a broken flap, using a small finishing nail and some JB Weld.
Benn holding up for a while now.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Blacklane
New Carlisle, Ohio USA
Posted: 02/25/23 08:18pm Link  |  Quote  |  Print  |  Notify Moderator
My solution is similar to KimK-NY. I used a straight piece of brass rod found at hobby stores and cut it to the same length as the two pivot pins. Then I taped it to the flapper using aluminum duct-sealing tape. The result is a flapper with brass pins and a stiff brass edge along the top. It has been working fine for a decade or more.
