RV.Net Open Roads Forum: Negative and ground wire questions
 > Negative and ground wire questions
ewarnerusa
Helena, Montana
Posted: 02/24/23 09:21am Link  |  Quote  |  Print  |  Notify Moderator
A spring project I have in mind is to upgrade the OEM power wire between the battery and converter to a larger gauge. I think it is currently 8 gauge and I want to upgrade to 4 gauge. The OEM setup is a long positive wire from 12V panel in the camper to circuit breaker on the tongue and then to the battery. The negative wiring from 12V panel is a short run from the panel to the camper frame.
Should I replace the short negative wire run with 4 gauge wire to same frame grounding connection? Or is it better to run negative all the way to the battery? Does a ground wire from battery to frame need to be of same gauge as the largest in the system?
Thanks.
* This post was edited 02/24/23 10:14am by ewarnerusa *
enblethen
Moses Lake, WA
Posted: 02/24/23 09:49am Link  |  Quote  |  Print  |  Notify Moderator
The steel frame has less resistance then a #4 wire. Connect with short piece.
Verify that the bolts connecting to frame is at least 5/16, 3/8 would be better. Clean from to bare metal and use de=oxidation compound. Do same at battery connection to frame.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ewarnerusa
Helena, Montana
Posted: 02/24/23 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the input enblethen. That is the answer I suspected and hoped for.
deltabravo
Spokane, WA
Posted: 02/24/23 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
Run a new, larger negative wire from the converter to the battery.
lenr
Indianapolis, IN
Posted: 02/24/23 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Do both. Technically there should be only 1 frame connection, but I've had no problem running a new negative battery to converter wire when the trailer already has 2 frame connections for negative return. I'm concerned about corrosion at frame which is often out in the weather.
Bobbo
Wherever I park
Posted: 02/24/23 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Wire to the frame is enough. Running a separate wire to the battery is belt and suspenders. Won't hurt anything though. (The wire from the converter to the battery will have more voltage drop than the wire from the frame to the converter. Using both reduces voltage drop even more.)
Bobbo and Lin
JBarca
Radnor, Ohio, USA
Posted: 02/24/23 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
I'll bring up something to consider.
How long are you planning on keeping the camper?
Do they use salt on the roads in your area in winter?
Is the camper stored outside uncovered most or all of the time?
I restore older campers, mainly the 10 to 20-year-olds range. All of them were not stored inside or had minimal cover when outside. You can learn a lot from an older camper on how things fail.
Frame ground is bad news as a wire conductor as the camper ages when exposed to the elements. The DOT lights use frame ground, the brakes are often set up from the factory using frame ground, the LP pipe, and, yes, battery negative needs to go to frame ground. Corrosion is alive and well in an older camper when stored outside. Aluminum or copper connectors on the wire to the frame are also exposed. This frame ground setup works as a DC conductor when the camper is new. As the camper ages, the corrosion will start making issues.
During a camper restore, I added a DC negative wire to the brakes and the DOT lights to eliminate the frame ground, as the wire connection terminals and the rusted metal connections were all bad. The camper brands I have worked on had the power converter already set up with DC negative with a wire directly to the converter. The weak link, though, was the exposed aluminum terminal block which joined all the DC ground wires at the frame by the battery. That area also gets corrected.
The suggestion is to run your upgraded heavy wire on the DC negative to the power converter if you want to keep the camper for a long time where corrosion conditions exist, as I asked about above.
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
larry cad
ohio
Posted: 02/25/23 05:43am Link  |  Quote  |  Print  |  Notify Moderator
If you use the chassis as a conductor, you have 4 connections, two at each end. If you use #4 wire, you have 2 connections. Reliability in electricity is a function of the number of connections. 2 is twice as reliable as 4.
If you decide to use the chassis anyway, be certain to use a corrosion limiter such as De-Ox, or similar. Once the connection to the chassis gets rusty, you are in line to have the next problem.
Our Travel Blog
