RV.Net Open Roads Forum: How to transfer large video from phone to computer
 > How to transfer large video from phone to computer
BarneyS
S.E. Lower Michigan
Posted: 02/26/23 07:09am Link  |  Quote  |  Print  |  Notify Moderator
I recorded a fairly large video on my Android cell phone last night. I would like to transfer it to my computer if possible. I have found the video on my phone but the file refuses to move from the phone location to my chosen spot in my computer. Why is that? Is there a way to do this?
On another note, is is possible to edit the video into smaller segments that will e-mail easily? I don't necessarily want to reduce the quality of the video if possible. They video is in Mp4 format.
Thanks for any help you can give me. I very seldom do this kind of thing with my phone or computer.
Barney
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
LouLawrence
Traveling the US fulltime since 2000.
Posted: 02/26/23 07:28am Link  |  Quote  |  Print  |  Notify Moderator
Assuming you are making the transfer with a USB cable you should have no problem. You will have to get your phone to give permission for the transfer with should cause a pop-up when you first connect with an Allow or Deny option. If that doesn't show up you need to look for something at the top showing USB options or in settings that will adjust what happens when you connect USB.
2oldman
NM
Posted: 02/26/23 08:12am Link  |  Quote  |  Print  |  Notify Moderator
There's a ton of google hits on this.
folivier
Southeast Louisiana
Posted: 02/26/23 08:29am Link  |  Quote  |  Print  |  Notify Moderator
Try emailing it to yourself. You'll get an error message but it should allow you to upload it to the cloud and then download it to your computer using that link. Assuming you use gmail.
1492
Arlington, VA
Posted: 02/26/23 09:26am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't try emailing a video as a file attachment. Instead send a link to it from MS OneDrive or Google Drive instead.
This is a Signature test on RV.net forum portal.
MitchF150
Puyallup, WA
Posted: 02/26/23 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Humm... I transfer photos, videos from my Android phone to my computer all the time.
Agree, you don't want to email anything that is more than 10mb in size...
but, once you find the file in the "DCIM" folder from your computer accessing the phone via a USB cable, it should just a 'copy' and then find the place on the computer you want to transfer to and then 'paste' it.
If it's a very large file, it might take a bit of time to transfer, but the file type should not really matter?
Anyway, good luck with it! Mitch
Tom_M
New Hope, MN
Posted: 02/26/23 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Once you get the video to your computer there is a basic cuts only video edit software called Avidemux. It's free and can be downloaded here:
https://avidemux.sourceforge.net/
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
wildtoad
Blythewood, SC
Posted: 02/26/23 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
One reason all my pictures are automatically uploaded to the cloud (iCloud that is) when WiFi is available.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Posted: 02/26/23 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Your phone is an external USB disc drive.. Like a Thumb Drive.. Simply plug it in to the computer with the proper cable and file copy using File manager on the computer.
Open file manager
Click on This comuter or My comptuer
Find the phoen at the bottom of the quick links and navigate to the video folder or search for it by name
johnhicks
Wandering below the Gnat Line
Posted: 02/26/23 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Not all USB cables are data cables, so be sure you have one that's not simply for charging.
You probably need to select on one or both devices that the connection is for file transfer, not charging.
-jbh-
