RV.Net Open Roads Forum: Tech Issues: stairs
 > stairs
Page of 5
Durb
NW
Posted: 03/07/23 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
profdant139 wrote:
John, that was a great write-up on the GlowSteps -- well done!
For whatever it is worth, I am also a happy GlowSteps camper -- we do a lot of boondocking in rough country, and the GlowSteps can cope with difficult situations.
But if I understand the OP's situation correctly, I'm not sure that GlowSteps would solve the problem of a very narrow site, with the bottom of the step an inch from a block wall. I don't know of any steps that would handle that issue.
With the Glowsteps, you can push them close to the trailer in an emergency and use them almost like a ladder. Use the upper 3 notch adjustment to make sure the rungs are level. They will protrude a lot less than fold down steps. Emergency use only as I wouldn't considering the limited rung surface as being desirable, but you can get into the trailer virtually anywhere.
profdant139
Posted: 03/08/23 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Durb, that is a clever solution -- I did not know that the GlowSteps could be used as a ladder.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
mhsmith
Toledo
Posted: 03/09/23 10:30am Link  |  Quote  |  Print  |  Notify Moderator
We purchased a 19 Flagstaff 29RKWS in 2020, but before we finalized the sale, we had to buy additional steps with one handrail and purchased a second to allow my wife to be able to get in and out. We bought a 5 step add-on which works well. Currently trying to come up with a way to mount them permanently so I don't have to go through unloading/loading them from the cargo compartment...not getting any younger. While made of aluminum, they are still somewhat heavy. The fold in the door steps are nice, but no easy or solid way to attach handrails. We have a three step, but if 5 could be placed in the same space, that may work well for us but unable to locate a 5 step. Don't know how to add a pic, below is where we purchased them.
http://rv-co.com
austinjenna
Columbus, Ohio
Posted: 03/10/23 04:59am Link  |  Quote  |  Print  |  Notify Moderator
When they first came out a lot of folks were happy because of the added stability they gave them. I know my wifes first thought after seeing them was - So isn't all the dirt/rain etc going to go inside the camper?
My first thought was that I would never be able to use them at the storage yard being in close proximity to the trailer next to me. I just figured if I ever bought a new trailer like that I would need to have them swapped out.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
Cptnvideo
Arizona - most of the time
Posted: 03/10/23 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
Bravo, Grit Dog. My favorite is the dumping of dirt into the RV. Apparently they either don't have a broom or the few seconds it takes to use one.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
fj12ryder
Platte City, MO
Posted: 03/10/23 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, that mud just brushes right off. [emoticon]
Face it, some of us hate them with a passion, because they're a PIA. You like them. Shoot, you could have mine if I could replace them easily.
But really, the worst thing about them is if you can't put the steps down, you can't get into your trailer. Smart engineering.
Howard and Peggy
"Don't Panic"
Lantley
Ellicott City, Maryland
Posted: 03/10/23 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
It's not about sweeping up the mess. It's about avoiding the mess in the first place.
Let's see, should I get the steps that brings dirt inside the RV or should I get the set that remains entirely outside?
That is not a hard decision.
Should I get the fridge that leaks a little bit, its not hard to wipe up. Or should I get one that does not leak at all.
Now to some degree the fridge example seems absurd. Of course you don't want a fridge that leaks.
That's how many feel about stairs that store inside and bring dirt, water and debris inside.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
profdant139
Posted: 03/10/23 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Well, no matter what, we seem to track in a lot of dirt and gravel. We have the GlowSteps, as I mentioned above. And they stay outside -- they are mounted below the door.
But we boondock in messy places -- ice, snow, mud, you name it. So we keep a boot cleaner near the front door, and a stiff whisk broom, and an astro-turf welcome mat.
None of that stuff works perfectly, but we can fool ourselves into thinking that we are doing our best to hold back the mess.
When it gets really bad, we have to take our boots off before coming thru the door. Like the time we somehow ended up in a cow pasture . . . .
Lantley
Posted: 03/11/23 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Tracking in dirt from shoes is normal and cannot be 100 % avoided.
Bringing in dirt that accumulates on the stairs themselves is not typical can be 100% avoided with a different set of steps.
Page of 5
 > stairs
