humblerb
houston
Another question as I am preparing to replace tires on my fifth wheel.
I am replacing due to age, not due to wear.
Question is with regard to the spare.
I know the best thing to do is replace all 5 with the same tire.
But, does it make any sense to replace the spare with a cheaper tire or leave the existing spare on (zero miles on it), with the thought that it would only be used until I can reach the next town?
Likes to tow
Huntington WV
My belief is that since the spare usually but not always is kept out of direct sunlight it should be good enough to continue being a spare for a while. My trailers have all had the spare underneath the frame and on the rare occasion that I needed to use or inspect it I found no cracks or obvious signs of deterioration. Age of the tire figures into the equation because after around 6 years they are not supposed to be used as a permanent tire. As with everything in our world right now tires are very expensive and buying 5 just to put one underneath as a spare is wasteful. But it depends on your financial situation and peace of mind. All of my spares on my RV and both boats are older tires that I have either pulled out of service or they came with the unit when new and I never replaced. I do however once a year check for dry rot and obvious knots or bulges or signs of separation. Keeping the lug nuts checked for proper tightness is more important than keeping new rubber as a spare!!
MFL
Midwest
Agree with above, as to need to replace spare. Age matters, and a tire not being used, can become rotted, more so than one being run at highway speeds.
Only you know, how your spare has been treated. Out of sun, properly inflated, and not more than 10+ years old? Are you towing long distances, or full timing? IMO, unless you fall under one of above, I'd use the current spare, rather than buy new, just to hang on the trailer.
Jerry
MarkTwain
Northern, Ca. , USA
RVing is %100 guaranteed to have "breakdowns" i.e. blown tires. Buy a new tire for the spare!!!!
JIMNLIN
Oklahoma
Also depends on the type of tire used. If the tires are 5-6+ years old and the usual load C/D/E ST maypops then they don't make a good reliable spare at that age.
If the tires area LT or a commercial grade load G or H ST then they make good spares for several more years....assuming their protected from the sun.
Now if the trailer sees maybe 1500 miles a year then cheap quality low cost tires may work best.
On the rv trailers I've owned and several GN or bumper pull service trailers I never buy a new spare.
Run a quality tire on a road trailer and the spare may never roll on the ground.
fj12ryder
Platte City, MO
The spare on our last trailer was never lowered in the six years we had the Sailun tires on it. I just replaced the rolling tires on our new-to-us 5th wheel with Sailun tires, kept the spare as a spare. Hate to waste money.
Howard and Peggy
"Don't Panic"
larry barnhart
wenatchee. wa usa
Because the tire you might need on the road to replace the blown tire tells me to buy the new spare then if needed you buy what you can get.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Thermoguy
Graham, WA
After a blowout and realization that I had problems with other tires (all due to age, tried to squeeze 1 more season) I had to use my spare which was also old. It worked fine for the remainder of my trip, a couple hundred miles and was still OK, but I replaced all 4 with new and used one I had to buy to get me through as the new spare. I think you will be OK with your spare, or use one of the 4 for a new spare and change 1 out each time you put new ones on the ground.
valhalla360
No paticular place.
MarkTwain wrote: RVing is %100 guaranteed to have "breakdowns" i.e. blown tires. Buy a new tire for the spare!!!!
Never had a blowout. 15yrs traveling by rv, around 6 months per year. Dad never had one and he was cheap with tires....so not exactly 100%.
We typically tell the shop to put the best old tire on the spare rim, when getting new tires. That avoids 20yr old spare but saves money.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
johndeerefarmer
Had three blowouts on one trip with 6 year old Westlakes. Spare was brand new and mounted under the trailer and it blew too..
Buy all 5 new!
2020 Ford 350 6.7 PSD & 2017 F150 3.5 EB max tow
GD Reflection 29rs
