RV.Net Open Roads Forum: Class A Motorhomes: Difficulty timing a 1995 Chevy 454ci
 > Difficulty timing a 1995 Chevy 454ci
Page of 13
udidwht
Seattle
Posted: 03/14/23 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
OutofTime wrote:
enblethen wrote:
OP: you need to recheck the distributor. rotate the engine to number one cylinder, align the timing mark on the vibration damper. It may be off one tooth.
Installing distributor can be tricky! the oil pump shaft doesn't always drop right in meaning the engine needs to be turned over one direction or another. Best to do manually with bar on crank or if lucky with serpentine bely.
I verified the harmonic balancer is good and has not slipped. I posted it earlier in the thread but I took a 1/4 extension and slipped it into the spark plug hole on the number 5 cylinder, then rotated the engine until the extension was jammed in place by the piston coming up. I then checked the balancer and found it approaching 4 degrees BTDC, so the balancer is safe to use as a timing mark. That's how I got it running again. I have adjusted the timing by ear by turning the dizzy to where it will crank when you just bump the key and it will start hot or cold, which is a big improvement.
However, it's still running rough and pig-rich. That's why I want to verify all the sensors and get a timing light on it to really get the timing as precise as I can.
Based on how it runs it may be down a cylinder so I still need to verify that as well. When I changed out the spark plugs the plug that came out of cylinder 7 was pretty fouled with oil, so the oil control ring on that cylinder is pretty worn out. That one might be down.
It also looks like at some point in the RV's life the catalytic converter was removed. The O2 sensor is still there, but I don't see the cat. That could also be a piece of the lovely smell problem coming from the exhaust.
I haven't done my audit of electrical grounds yet, was focused on getting it running. I agree that bad grounds cause strange behavior. I had an Outback that was a crusty northern car and it ate headlight bulbs and shifted really rough until I cleaned all the grounds. The battery cables can probably stand to be replaced, but I'll get there.
I also need to go through the general wiring as the electric fan on the radiator doesn't seem to be running once the engine gets to temp and it sounds like the mechanical fan needs a new clutch. I also haven't seen the tiny engine bay cooling fans kick on either. Plenty of work to do in order to get this one sorted.
Does anyone know what color spring is needed for the 94-95 FPR? I can find plenty of kits with springs that claim they work for 94-95, but they also claim to work all the way back into the 80's model years so I don't know how that is possible with the change in fuel pressure in 94-95.
As long as you guys are willing to offer wisdom, I'll offer updates. This is my first GMC engine and chassis so much for me to learn here.
Contact the following and they will help you attain or get info on which spring you need.
https://www.sprperformance.com/
As for the auxiliary fan it runs via the sensor in the passenger side head. Closes to ground at approximately 221F. Check to see if you have power at the connector if you ground out the sensor. I believe the wire from the sensor runs thru the relay under the doghouse (attached to firewall near accelerator pedal). Check to see if the relay is working.
It will also come on when the AC pressure reaches approximately 225psi. I also ended up replacing the AC drier bottle, o-rings and adding approx 4-4.5oz of AC oil and new R-134a charge.
The fan is attached to AC condenser w/integral oil cooler. I did a write up on my P-30 just last year when I replaced the AC condenser w/integral oil cooler (lots of pics) you can read/see here:
https://www.gmt400.com/threads/condenser-oil-cooler.59140/
* This post was last edited 03/14/23 02:25pm by udidwht *   View edit history
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 58,301 miles and counting....(as of 06/08/19)
VIN# 1GBJP37N4R3314754
Flight System Generator man 360 (PM me)
enblethen
Moses Lake, WA
Posted: 03/14/23 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
What spring kit did you get and what color springs?
here is information for one kit:
This kit comes with 3 sets of advance springs to allow you to adjust the rate of spark advance from quick (Brown), to super-quick (Silver), to ultra-quick (copper).
In this kit, I would use none. I remember mine as being green.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
OutofTime
Posted: 03/14/23 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Spring Kit? I haven't ordered any kits yet. Are you referring to a spring kit for vacuum advance? My dizzy is electronic advance. I am trying to get the correct spring for the fuel pressure regulator as 1994-1995 BBCs have a different fuel pressure requirement from years prior.
OutofTime
Posted: 03/14/23 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have updates. Today I worked with my brother and we got the base timing set to 4 degrees BTDC using a timing light. Once computer advance turned on it advance to around 16 BTDC at idle. It seems to be idling much better and will idle around 850rpm or so when warmed up and on closed loop running.
However, it's still running a bit rich and still stumbling and falling on its face when revved. I pulled the IAC, cleaned it and the bore it sits in and checked for operation. I did see the pentile tip move in the throttle body when I turned the key to the run position.
I checked the voltage on the TPS and at full stop it read .568V, which is within spec I believe.
At this point I'm thinking my next move to fix this rich running is to replace the FPR.
udidwht
Seattle
Posted: 03/14/23 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
The advance at 16 after connecting the distributor wire is correct.
Idle at normal operating temp should be 800rpm. There is an idle set screw covered by the factory on the front side facing forward. Is it covered? If it is don't mess with it. If it isn't covered then it's likely some PO did mess with it.
The coolant temp sensor in the front side of the intake manifold will need to be checked. If it's running rich after warm up it is likely bad.
Get a ohm meter and ohm it out.
Coolant sensor approximate resistance specifications:
177 ohms @ 212 deg. F. or 100 deg. C.
241 ohms @ 194 deg. F. or 90 deg. C.
332 ohms @ 176 deg. F. or 80 deg. C.
467 ohms @ 158 deg. F. or 70 deg. C.
667 ohms @ 140 deg. F. or 60 deg. C.
973 ohms @ 122 deg. F. or 50 deg. C.
1188 ohms @ 113 deg. F. or45 deg. C.
1459 ohms @ 104 deg. F. or 40 deg. C.
1802 ohms @ 95 deg. F. or 35 deg. C.
2238 ohms @ 86 deg. F. or 30 deg. C.
2796 ohms @ 77 deg. F. or 25 deg. C.
3520 ohms @ 68 deg. F. or 20 deg. C.
4450 ohms @ 59 deg. F. or 15 deg. C.
5670 ohms @ 50 deg. F. or 10 deg. C.
7280 ohms @ 41 deg. F. or 5 deg. C.
9420 ohms @ 32 deg. F. or 0 deg. C.
12300 ohms @ 23 deg. F. or -5 deg. C.
16180 ohms @ 14 deg. F. or -10 deg. C.
21450 ohms @ 5 deg. F. or -15 deg. C.
28680 ohms @ -4 deg. F. or -20 deg. C.
52700 ohms @ -22 deg. F. or -30 deg. C.
100700 ohms @ -40 deg. F. or - 40 deg. C.
For TPS info:
https://www.gmcmi.com/wp-content/uploads/2013/02/TBI-Initial-calibration.pdf
OutofTime
Posted: 03/15/23 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
More updates. Put in a new ECT and it runs the same, if not a little worse before getting to closed loop. I think the new ECT is defective as at 72F it was clocking about 2.55k Ohms, which according to the chart provided is not correct. Are there any brands of ECT that are better than others?
Also, I'm thinking that the FPR is the cause in part for the black smoke and almost stalling when you rev the engine. I have a TBI rebuild kit for a 5.7 that has the right gaskets and I have a spring on the way from shop link provided, so that should hopefully correct the FPR.
Also getting plenty of backfires when putting the engine under load.
Thoughts?
udidwht
Seattle
Posted: 03/15/23 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thoughts?
As for parts & GM always go with Delco and/or Delphi. Any others will almost always cause headaches. Did you ever check the fuel pressure?
As for exceptions to the parts...I've had good luck with NAPA Belden Edge for spark plug wires (truck wires) and as for spark plugs Autolite.
Be sure and wrap the wires with heat cloth rated for at min 1500-2000F.
Back fire/s under load suggests either...
1. Burnt and/or bad spark plug wire/s
2. Crossed wire/s (out of firing order)
3. Fuel pressure related
4. Distributor issue (cracked reluctor)
* This post was last edited 03/15/23 09:47pm by udidwht *   View edit history
enblethen
Moses Lake, WA
Posted: 03/15/23 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
My book shows ECT at 77 degrees to be 2796. Your reading is close enough.
Have you verified year of the chassis? What is eighth character in VIN?
What is tenth character in VIN?
* This post was edited 03/15/23 06:38pm by enblethen *
OutofTime
Posted: 03/17/23 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Moar updates. Yesterday I changed out the thermostat and installed a new ECT that clocked much closer to chart when ohm'd. Existing thermostat was a 195F which is good, but from what I was seeing it was quite old. I also inspected the wire harness ground on the water neck stud... it was not so great. Cleaned it up and all the metal in that particular stack for a solid electrical connection. This morning I replaced the blown out PCV valve, replaced a failing vacuum line from the Evap valve to the throttle body and fixed the cracked boots on the PCV valve vacuum line. I also replaced a fuel filter of unknown age with a new Wix one.
Before I test fire it again I intend today to clean the ground strap from the rear of the driver's head to frame and wherever the negative battery terminal is grounded to.
I'm hoping after all this work I see some improvement. We'll find out this afternoon.
udidwht
Seattle
Posted: 03/17/23 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Good job on the ground bracket near the T stat. Often overlooked. The ground cable on my battery runs straight down to he frame. Cables will sometime corrode inside the sheathing so look them over real good. Also check and clean the positive from battery to starter.
Once clean & tight give them a coat of 'Super Lube' to protect from corrosion.
Page of 13
