RV.Net Open Roads Forum: Class C Motorhomes: Sprinter diesel tow question
 > Sprinter diesel tow question
ncrowley
Utah
Posted: 03/12/23 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Determine the weight you can pull by using the following calculation:
GCWR - GVWR
For these smaller RVs, you can assume you will be close to your GVWR. Do not be fooled by the hitch rating, which is 5000 pounds. That is more than the Sprinters can pull.
Use the Winnebago View as an example. All of the models have a GCWR if 15250 pounds and a GWVR of 11030 pounds. The difference is 4220. Therefore, the most you can pull is 4220.
Personally, I would not want to pull right at the max. My Jeep weighs 4400 pounds and therefore cannot be pulled with any of the View models. These numbers are about the same for all of the Sprinter chassis models I have seen.
Nancy
Newmar Northern Star
Posted: 03/12/23 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
GCWR - GVWR
That’s a very simplistic and conservative approach, although lacking in analysis and not entirely correct.
IE. A low profile trailer (toad that’s 3’ behind a huge box) adds no additional payload (gvw) to the tow vehicle and virtually no additional wind resistance.
A 4klb Jeep behind a motorhome will tow about the same as a mini canned ham camper behind a low profile tow vehicle (IE normal vehicle not a box van). Possibly easier.
Pretty easy to see how easy it is on the tow vehicle simply by looking at the change fuel mileage, which is minimal in this scenario. And the majority of that is due to rolling resistance only.
The additional stress on the drivetrain (the only plausible consideration with a dolly or 4 down toad with brakes) is very small.
Suspension? No concern, it’s not loading the tow vehicle suspension.
Brakes? No concern at all if you have toad brakes.
Weight ratio? No concern pulling 2 tons that doesn’t tail wag the dog with a 5-7 ton doooley tow rig.
klutchdust
Orange, California
Posted: 03/12/23 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
When I pulled my JK behind my Class C I saw no difference in fuel mileage or feel. It felt like it was not even there. I had a braking system on the Jeep so stopping was not an issue. The tongue weight is next to nothing, just the weight of the tow bar. When I towed a 18ft trailer loaded with race stuff and weighing in around 5K there was a huge difference. So even though the weights are the same the tongue weight changes things.
A friend tows his 70'ish Landcruiser behind his MB and he backs up what I just said. He doesn't feel any change with it back there.
* This post was edited 03/12/23 01:27pm by klutchdust *
Posted: 03/12/23 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
^Agree.
Statements like ncrowley and others make are from speculation or their personal want to be heard for some reason…
