Toolguy5
Columbia Station, Ohio
I switched them out when i had the 2018 Northpoint. It was pretty easy. I did have to modify trim on interior of door.
You need the correct measurements for the steps to work properly. They do make different sizes. It depends on ground to floor measurement wether you need 3 or 4 steps.
Dan & Patty
Miss Pickles the Pomeranian Princess
2020 GMC 3500 Sierra Denali 6.6 Duramax / Allison tranny
2021 Jayco Eagle 319MLOK
BWRVK 3710 companion
Maddy the Pampered Pom @ Rainbow Bridge 12-3-2013
Durb
NW
I replaced the fold-down steps on my 2008 trailer with Glowsteps that I bought used. I first ensured they were the same width. 2 bolts with nuts on each side, unbolt one set, install the other; real easy. Storing and deploying them took a few minutes of learning, but quite intuitive now. I did install some grip tape as I felt the Glowsteps might be slippery when wet. Good add.
I believe Torquelift makes a bracket so the steps can be folded into the doorway should your next trailer not have a nacelle under the door.
Bob Vaughn
Seffner, Fl.
We love ours would not have a set of solid steps
