RV.Net Open Roads Forum: Truck Campers: Michelin commercial tire lifespan
 > Michelin commercial tire lifespan
Slymer
Ontario, Canada
Posted: 03/03/23 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have a set of Michelin XDS2 commercial tires. 245/70 R19.5 16 ply, Load range H, up to 220 PSI. Our camper is an AFox 811. There is tons of tread left on these (all tires with approx. same tread wear if not identical). However these are 7 years old now and I am wondering if anyone has run tires like this beyond the recommended 7 year lifespan ??
Posted: 03/03/23 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Well they’re not 220psi tires, but aside from that, it’s more about the condition of the tires than the age, at only 7 years old.
7 years parked in the sun in Arizona = throw them away, yesterday.
7 years with fairly regular use but parked in a garage in Ontario likely means they have more years left in them. I wouldn’t even think about replacing them if they haven’t seen an inordinate amount of UV exposure and aren’t showing any signs of dry rot.
Posted: 03/03/23 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Nice setup though!
AF 811/860 is my fave camper. Big camper features and short bed ready!
If it helps your peace of mind, I hauled our AF860 all over the country on cheapo weak, squishy sidewall, 5-6 year old OE takeoff Firestones. Without issue. Running 75mph + consistently on the open road.
I’d trade a brand new set of those tires for your old 19.5s, today, and be even more confident!
As long as they aren’t dry rotted.
Note, you can’t see some dry rot on fully inflated tires.
Try this. Deflate one of the tires on the truck until almost flat and see if there’s any cracking in the bottom part where the tire is flexed. If not, good to go.
Tom/Barb
Oak Harbor, Wa
Posted: 03/03/23 01:45pm Link  |  Quote  |  Print  |  Notify Moderator
run them. 10 years is the life span
Slymer
Ontario, Canada
Posted: 03/03/23 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Grit Dog,...correct,...not 220,....120 psi (typo)
* This post was edited 03/04/23 07:24am by Slymer *
Bedlam
PNW
Posted: 03/03/23 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced mine after 7 years and 60k+ miles even though the tires still had good tread. I look at this as preventive maintenance and factor in the cost of camping. My truck sits outdoors and is not sheltered in a garage but the weather is mild on rubber in area. If it was garaged, I would be willing to run them longer.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
jimh406
Western MT
Posted: 03/03/23 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I only do 6 years on my vehicles. Tires are relatively cheap compared to the aftermath and/or being stranded by a catastrophic failure.
The problem is tires can still fail even though the look fine if the tread separates from the carcass.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
wildtoad
Blythewood, SC
Posted: 03/04/23 06:46am Link  |  Quote  |  Print  |  Notify Moderator
If swapping tires at 6/7 years regardless of condition makes it easier to sleep at night, great. Tire manufacturers support a 10 year discard timeframe with proper care and annual inspections after 7.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Oregun
Oregon
Posted: 03/05/23 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have Cooper 245/70/19.5 tires for 7.5 years.
When I bought them the tire guy said they would last 10 years.
So I looked on Cooper's website and they had a page about LT tires lasting 10 years.
Sent them an email and they recommended 6 years for RV tires.
JIMNLIN
Oklahoma
Posted: 03/05/23 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
michelin Q&A
What is the expected service life of tires?
While most tires will need replacement before they achieve 10 years, it is recommended that any tires in service 10 years or more from the date of manufacture, including spare tires, be replaced with new tires as a simple precaution even if such tires appear serviceable and even if they have not reached the legal wear limit.**
The OP truck is a F350 srw.. more along the line of the same truck we use in commercial service carrying same heavy loads in the bed.
