SteveG36
Phoenix
2007 Keystone Raptor. Old but well maintained.
Was camping in Flagstaff so my kids could play in the show and as luck would have it we encountered an epic 3-day snow storm. It was cold outside but not the coldest I have had the trailer in (hovered right around 30-32 degrees). My trailer is winterized - although I realize that does not mean much.
I had a hook up but I did not leave the black tank open because I did not have a heating wire for the sewage pipe and figured since we were there just a few days, I would dump at the end.
One of the boy stayed back to “Use the facilities” while the rest of us went out to play in the snow and when we returned to the trailer it WREAKED of sewage. I mean it was bad. We immediately blamed it on our son who just “used the facilities” and wrote it off, but it was BAD and the smell was lingering.
A few minutes later I began to pack up the trailer to leave and I noticed a big yellow/brown ice-cycle hanging from the trailer to the ground underneath where the black dump pipe comes out of the sheathing that covers the bottom and water was still leaking down it. UGH!!!
This weekend I brought the trailer home, opened it up underneath to find the problem. The issue, I cannot find anything. All of the pipes look good. I filled the black tank until the light came on saying it was full with fresh water and there is NO leak that I can find. I even overfilled it a bit to see if it would leak. I don't want to over do it, but still no leak.
It is entirely possible that the tank filled up while we were in Flagstaff and before I dumped it but if something burst or broke I should see a leak now with a full tank and there is nothing. Additionally, There is no overflow on a black tank that I am aware of so I have ruled that out.
I am completely perplexed. What could have happened? I am afraid to seal everything back up because SOMETHING clearly happened to created that poop/peecicle.
Looking forward to your thoughts and expertise.
It is absolute the tank filled with that much use on a trailer.
And there is a leak. may be where the pipes enter the tank may be the seal between toilet and pipe.
RAS43
Littleton,CO
It is possible that there is a leak at the connection between the tank and the vent pipe that goes up to the roof. Fill the tank full to check by filling with a hose thru the toilet so you can see when it is full. Be sure to have a shut off on the hose.
wa8yxm wrote: It is absolute the tank filled with that much use on a trailer.
Lol, I love your certainty but question your process of deduction….
opnspaces
San Diego Ca
How full was the tank when you found the icicle? If the tank was only half full it takes things like the vent pipe out of the equation.
You're going to have to fill the tank fuller to test this. I would fill the tank to the top of the tank by looking down into the toilet while filling. Use low pressure from a hose so you don't get any splash back in the RV or in your face.
Let it sit for an hour.
If no leaks the problem is either the vent pipe seal or the toiled to tank gasket. Personally if I couldn't find a leak with the first test I would just pull the toilet and replace the gasket. It's a whole two nuts and unscrew the water line and the toilet is out. Remove the old foam gasket and put a new RV toilet gasket in place and reinstall the toilet.
If you really want to explore further after replacing the gasket then fill the tank until the water is up into the toilet bowl and see if you get any leaks.
Could the leak have been from an overflowed gray tank?
Also I would crawl under the trailer and look up around where the icicle was. Are you sure the icicle was waste and not stained water leaking down the walls from a roof leak?
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
dougrainer
Carrolton, Texas
1. If you stated your post correctly. YOU NEVER LEAVE THE DUMP VALVES OPEN WHEN CAMPING. ESPECIALLY THE BLACK TANK. COLD or Hot weather
2. If you doubt this, look up POOP PYRAMID.
3. Tanks, the down pipes are supposed to be sealed on top the tanks. As another posted, fill up the Black tank full and then slowly fill the rest of the tank THRU the toilet, until water comes up into the bowl. Once you do this, if the vent pipe or the toilet pipe and gasket are NOT sealed you will see water drip on the ground. No leakage, your system is OK.
4. IF you camp with the Black Valve OPEN, you will have a poop pyramid. THESE SMELL HORRIBLE.
5. Your relative did nothing to cause this problem.
6. If you have a Black Tank flush, this may be a leak area, but the fill test will confirm this. Doug
PS, tanks have NO overflow system
groundhogy
PA
Possibilities:
-Your gate valves need service.
-you need to tighten, add gaskets, to your exit hoses. I have sometimes doubled up gaskets.
-if people don’t flush enough, the urine smell can rise up due to repeated coatings
ScottG
Bothell Wa.
Was the roof vent covered in snow?
valhalla360
No paticular place.
dougrainer wrote: 1. If you stated your post correctly. YOU NEVER LEAVE THE DUMP VALVES OPEN WHEN CAMPING. ESPECIALLY THE BLACK TANK. COLD or Hot weather
In warm weather or long term, I agree with your assessment.
For a quick weekend in really cold weather, I'll disagree (30F is not really cold weather).
One weekend isn't going to create the pyramid and assuming you otherwise let the tank fill and sit a bit between dumps, anything that does start with get taken care of by sitting in the half full tank.
The trade off in really cold weather (assuming you don't have heated tanks) is that things freeze and bust.
As far as the OP's issue, it's possible that things got pressurized if the vent tube slipped down towards the bottom of the tank. When the airspace warmed up during the day, the pressure had no where to go except to push water up vent tube. It overflows and runs back down the outside of the tube before dripping down and forming icicles. The waste water could also find it's way into the walls where a lovely aroma can develop.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
dougrainer
Carrolton, Texas
valhalla360 wrote: dougrainer wrote: 1. If you stated your post correctly. YOU NEVER LEAVE THE DUMP VALVES OPEN WHEN CAMPING. ESPECIALLY THE BLACK TANK. COLD or Hot weather
Really? You are an expert on just a weekend? There is usually very little water flushed when toilet is dumped. The S**t goes straight down and hits the bottom of the tank. Now, you are the expert. HOW MANY people used this on the weekend? YOU DON'T KNOW. THE TANKS HAVE VERY LITTLE SLOPE. So, everytime you dump the toilet the debris plops down on top the previous and without adequate water(GONE because the valve is open) the debris just stacks up. Sorry, after 43 years as a Tech I make good money getting rid of the Pyramids. Doug
