RV.Net Open Roads Forum: Tech Issues: Trouble with Poop Chute
 > Trouble with Poop Chute
SteveG36
Phoenix
Posted: 03/13/23 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
So I figured out my issue.
I opened the bottom so I could see the tank and I very carefully filled up the black tank until it was full full (using an endoscopic camera). What I found is that the seam of the tank at the top where there top is glued or heat welded to the bottom part of the tank is leaking ever so slightly. Thinking about what occurred, I believe that I let the tank get too full and it froze/expanded and separated the seam a bit. The leak is very small so I am going to try a repair with some West Marine G/flex epoxy. I did a bunch of research of all the products people have used and it seems this one has done really well for others. The other thing I can do is monitor the tank a little bit better and not let it get filled to the point where it would leak (although if it were full while driving I assume w/sloshing it may still leak if I did not repair it.)
If this does not work I will replace the tank next spring completely when I have more time. Right now I am drying out the tank so that I can repair it this coming weekend.
I appreciate everyone's feedback, it was very helpful and gave me some things to look at while I was still perplexed.
pianotuna
Regina, SK, Canada
Posted: 03/13/23 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
SteveG36,
If the repair doesn't last try some eternabond. It can even be applied under water.
Regards, Don
valhalla360
No paticular place.
Posted: 03/13/23 07:44pm Link  |  Quote  |  Print  |  Notify Moderator
dougrainer wrote:
Really? You are an expert on just a weekend? There is usually very little water flushed when toilet is dumped. The S**t goes straight down and hits the bottom of the tank. Now, you are the expert. HOW MANY people used this on the weekend? YOU DON'T KNOW. THE TANKS HAVE VERY LITTLE SLOPE. So, everytime you dump the toilet the debris plops down on top the previous and without adequate water(GONE because the valve is open) the debris just stacks up. Sorry, after 43 years as a Tech I make good money getting rid of the Pyramids. Doug
Yes, done it often when weather is really cold and on a sewer site...never had an issue but then it gets lots of use under normal conditions between the really cold weekends.
On sewer, you should be using lots of water anyway but if it's only an occasional weekend, any start of a pyramid will break down before then next time.
The Pyramids are mostly folks who just leave the valve open all the time...often at permanent sites...there I agree, you are setting yourself up.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
