RV.Net Open Roads Forum: Class A Motorhomes: Driver’s license for DPs
 > Driver’s license for DPs
kohana
around
Posted: 03/05/23 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
So, I want to switch from 5th wheel to a DP but I’m confused about the CDL requirements.
What do you all due ?
Thanks Bob
2006 Ram 2500 Cummins, 6 sp manual, pacbrake
2011 Montana Mountaineer 335RET, Mor/ryde PB
Trailersaver BD3 hitch--Smooth ridin'
CA Traveler
The Western States
Posted: 03/05/23 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Check the DVM requirements for your home state for license requirements. DLs are recopical in all other states.
2014 Grand Cherokee Overland
Bob
BB_TX
McKinney, Texas
Posted: 03/05/23 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
Not likely you will need a CDL. But most likely you will need a higher level non CDL license than a standard license. Requirements differ by state. Example is Texas that you need a class A or class B non CDL license for any thing with a GVWR of over 26,001 lbs.
Google drivers license for your state.
kohana
around
Posted: 03/05/23 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I saw that but the only info I’ve found involved 2-4weeks of school. I’m thinking you guys aren’t doing that so what am I missing. Tax is a good example.
BB_TX
McKinney, Texas
Posted: 03/05/23 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
School for a commercial drivers license. Not for a personal use RV. What is your state of residence?
AllegroD
Outdare
Posted: 03/05/23 09:26pm Link  |  Quote  |  Print  |  Notify Moderator
None, in my state.
ArchHoagland
Clovis, CA, USA
Posted: 03/05/23 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
What state do you live in?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Campinghoss@51
Windsor NC
Posted: 03/06/23 04:27am Link  |  Quote  |  Print  |  Notify Moderator
In NC anything over 26001 lbs required a B CDL. All I did was download the handbook for CDL and studied it one night. Then took the written test. I also had to drive my dp with the examiner with me. Piece of cake.
Since switching back to a fiver I plan to keep the B license now that I have it.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
JRscooby
Indepmo
Posted: 03/06/23 04:31am Link  |  Quote  |  Print  |  Notify Moderator
I live in Mo. Last November, when time to re-new, I asked about driving a MH if did not keep CDL. Now I have just normal state DL
rdhetrick
Posted: 03/06/23 05:06am Link  |  Quote  |  Print  |  Notify Moderator
Actually, NC doesn't require a CDL for private use of a motorhome, they require the regular license for the appropriate CLASS of vehicle, which for most DP's is a CLASS B. So what you have is a Non-commercial Class B license.
What people don't seem to grasp is that the CLASS of a license has nothing to do with it being commercial or not - it is simply a designation for the type of vehicle you are allowed to operate.
A "CDL" just means it's a Commercial Driver's License. It also needs a CLASS qualification. The most common is the Commercial Class A, and this is what people think of when they hear "CDL", but I know people that have a Commercial Class B license. They can drive a vehicle over 26,000 lbs but the trailer is limited to 10,000 lbs.
Many states, but not all, are the same way.
I doubt there are many RV'rs that actually have a Commercial license, except those that drive for a living...
Rob - Solo Full Timer
2017 Winnebago Travato 59G
Former 2006 Mandalay 40E
