RV.Net Open Roads Forum: Class A Motorhomes: Driver’s license for DPs
 > Driver’s license for DPs
Posted: 03/06/23 05:09am Link  |  Quote  |  Print  |  Notify Moderator
Laws vary from state to state. Some states reaquire special endorsements for any vechicle that has air brakes.. Or any vehicle that's over xxxxx pounds or so many feet long or or or or or or
Some don't.
However one thing that is common to all states.. If your license allows you to drive it in your home state... You are good in whatever state. And a good part of Canada as well (not sure about all of Canada)
So you are going to have to research your state.
wolfe10
Posted: 03/06/23 05:52am Link  |  Quote  |  Print  |  Notify Moderator
ArchHoagland wrote:
What state do you live in?
Yup, without that information, you will get quite a lot of good advice that applies to OTHER states, but may not apply to where you are licensed.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
rhagfo
Portland, OR
Posted: 03/06/23 07:00am Link  |  Quote  |  Print  |  Notify Moderator
kohana wrote:
I saw that but the only info I’ve found involved 2-4weeks of school. I’m thinking you guys aren’t doing that so what am I missing. Tax is a good example.
Well you need to check with your state DMV about licensing requirements. We live in Oregon and there is no special requirements.
LouLawrence
Traveling the US!
Posted: 03/06/23 11:42am Link  |  Quote  |  Print  |  Notify Moderator
FL requires nothing! TX requires a Class B certification for all RV's over 26,000#. Training book is something like the last 10 pages of the CDL training manual. It's really stupid and worthless information. This is followed by a driving test at the local DMV.
Other State's requirement WILL vary.
BB_TX
McKinney, Texas
Posted: 03/06/23 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
LouLawrence wrote:
FL requires nothing! TX requires a Class B certification for all RV's over 26,000#. ………..
Unless you are towing something with a GVWR over 10,000 lbs, then Texas requires a class A non CDL license. That would be the case of most all trucks towing large 5th wheels and motor homes towing larger utility trailers or even a larger pickup. A MH towing something under 10,000 lbs GVWR can get by with a class B license.
And that is “weight rating”, not actual weight.
dieseltruckdriver
Black Hills of SD
Posted: 03/06/23 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
rdhetrick wrote:
Actually, NC doesn't require a CDL for private use of a motorhome, they require the regular license for the appropriate CLASS of vehicle, which for most DP's is a CLASS B. So what you have is a Non-commercial Class B license.
What people don't seem to grasp is that the CLASS of a license has nothing to do with it being commercial or not - it is simply a designation for the type of vehicle you are allowed to operate.
A "CDL" just means it's a Commercial Driver's License. It also needs a CLASS qualification. The most common is the Commercial Class A, and this is what people think of when they hear "CDL", but I know people that have a Commercial Class B license. They can drive a vehicle over 26,000 lbs but the trailer is limited to 10,000 lbs.
Many states, but not all, are the same way.
I doubt there are many RV'rs that actually have a Commercial license, except those that drive for a living...
Excellent post regarding CDL information. I do have a CDL since I used to drive truck.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
JaxDad
Greater Toronto Area
Posted: 03/07/23 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Some don't.
That is sound advice, reciprocity covers your drivers license, but not endorsements or other required permission.
In numerous jurisdictions (including here in Ontario) the equipment regulations require that an air brake system be inspected (visual and function) on every day the vehicle is in motion by a ‘certified technician’, the air brake endorsement is that certification.
While it’s rarely enforced, usually only in spot checks or following an incident, it’s a potentially expensive lesson if you don’t have it.
Another misunderstood point with ‘equipment regulations’ that comes up with DP’s is overall length. If you pull a trailer and live in a State where 65’ is the legal maximum, say in Florida, you might have a problem when you cross into Georgia where it’s only 60’ maximum.
willald
NC
Posted: 03/09/23 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Yes, every state is different. I know in NC, anything over 26,001 lbs GCWR, you are technically supposed to have a non-CDL class B.
However, I have learned over the years that not many people that own DPs actually go and get that B license, and most law enforcement officers either do not know about this license requirement, or do not care.
I have a friend I have known for almost 20 years in the RV sales business. A few years ago, I asked him about this issue with licensing, and larger Motorhomes. He and his dealership sells tons of DPs, and have for many years.
He told me that although they are required by law to inform customers buying DPs of the license rules (and they do)...None of his customers ever have got the upgraded license. Nor have any ever had a problem, that he knows of.
Furthermore, he told me how he and other sales reps he works with drive the big DPs all over the state to various RV shows his dealership is in. None of the sales reps have a B license. And, yes, he has been stopped a couple of times, and law enforcement officers always either don't know or don't care about this issue, as nobody has been cited for it that he knows of.
At any rate, I am not advocating anybody ignore the law about this. Just wanted to point out that in some cases, laws like this are not enforced or noticed much.
This is actually one of the reasons I prefer gasser Motorhomes that stay under that 26k limit. I would definitely not want to have to get a special license to drive our RV (even if the law doesn't enforce such).
Will and Cheryl
2021 Newmar Baystar 3014 on F53 (7.3 V8) Chassis ("Brook")
2018 Jeep Wrangler JK ("Wilbur")
BobGed
Carson City, NV
Posted: 03/09/23 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
IMHO it's not law enforcement you need to be worried about, however it is the ambulance chasing attorneys if you're ever involved in an accident, at fault or not.
2017 Tiffin Phaeton 40QBH
2014 Jeep Cherokee Limited
FRFrank
Finger Lakes
Posted: 03/10/23 03:35am Link  |  Quote  |  Print  |  Notify Moderator
Whatever license classification is required should come with a super strict physical examination and vision test for seniors.
