RV.Net Open Roads Forum: General RVing Issues: Did I damage my house batteries?
 > Did I damage my house batteries?
MetalGator
Posted: 03/09/23 09:05am Link  |  Quote  |  Print  |  Notify Moderator
I replaced my house batteries back in August of 2020. I got 3 1/2 years out of the first set of house batteries (bought motorhome new). We are going on a trip tomorrow so I checked the water level in my batteries and noticed white crud on the battery strap. One of the batteries was swelling and was wet. These batteries are only about 2 1/2 years old. Called the local RV shop and replaced both of the house batteries. When I checked the new batteries, the water barely covered the plates.
I always fill the batteries much fuller than these new batteries were filled. I am wondering if I have been overfilling my batteries and that is why I am not getting more time out of them (and the swelling). My first set of batteries swelled as well.
I do keep my motorhome pulled in 24/7 so there could be an issue there as well.
Any advice to get more time out of my house batteries?
Burch
2018 Miramar 35.3 Motorhome
3 fur kids (Monty, ZuZu and Pinto)
Rainbow bridge (Murphy, Petie, Lola)
way2roll
Wilmington NC
Posted: 03/09/23 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like overcharging.
2023 FR Sunseeker 2400B MBS
MFL
Midwest
Posted: 03/09/23 09:53am Link  |  Quote  |  Print  |  Notify Moderator
All converter/chargers are not equal. Depending what you have, it may not go to float charge, 13.2volts, when plugged in 24/7. If the charger you have, maintains 13.6, or more, you may be cooking (overcharging batteries).
My battery is original, and 10 years old. Always plugged in, other than when removed over Winter. My converter/charger is a Progressive Ind smart charger.
Jerry
johnhicks
Wandering below the Gnat Line
Posted: 03/09/23 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Battery water level should be at the bottom of the tube/slot or slightly lower but still covering the plates when looking down the filler hole. It should never be actually full. A common plastic battery'watering jug will take care of the level.
Sounds like they're being overcharged. Right now, with normal fulltime usage and plugged in, my converter is putting out 13.3 volts.
Batteries do of course fail. I had a pair of Interstate Grp 31 batteries that lasted six years, then supposed equivalent Walmart Everstart batteries that lasted all of 14 months, and now a pair of Crown GC2 that are a little over three years old.
-jbh-
Posted: 03/09/23 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Agreed, not overfilled but likely overcharged.
Fwiw I typically fill flooded batteries to almost the top of the slot. Not an issue for boiling over if not egregiously overcharged.
If your converter isn’t smart enough to trickle/float and/or you have a WFCO converter that actually charges like it should it may be the cause of cooking a battery or 2.
Another possibility but not likely is the alternator on the rig “could be” overcharging them.
Hard to tell though based on your observation, presumably after a long storage.
JimK-NY
NY
Posted: 03/09/23 10:45am Link  |  Quote  |  Print  |  Notify Moderator
After checking to be sure you are not overcharging, you might want to consider AGM batteries next time. They cost more but generally last longer and do not require maintenance.
2oldman
NM
Posted: 03/09/23 11:48am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, or lithium.
Johnny G1
Clearwater, British Columbia ,Canada
Posted: 03/09/23 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
You want to get your charging unit checked first before you even think of going AGM batteries as they usually take a different charge pattern, I have had batteries last as long as 14 yrs so there is something wrong in your Mh.
98 Mountain Aire 34' 210 Cummins Puller and 2001 dodge dully with all the toy's, 400 + hp pullin a 2001 32.5' Okanogan 5th wheel, new to us after 5 yrs with the 28' Travel Aire. Lots of fun.
2oldman
NM
Posted: 03/09/23 12:28pm Link  |  Quote  |  Print  |  Notify Moderator
Are you thinking of Lithium? AGMs may vary, slightly, but not to have to change out charging systems. They're still an acid battery.
time2roll
Posted: 03/09/23 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Fill to 1/4" to 1/8" below the split ring that extends down into the cell. Fill after fully charged as the electrolyte will expand as it charges. Although the plates need to be covered before charging. Just touching the split ring is absolute max and may still have some electrolyte pushed out and cause corrosion. Swelling and wet of one battery sounds like a shorted cell and is fairly common.
Charging voltage can make the issue worse. Plenty of equipment charges at a voltage too low and floats at voltage too high. Post the converter or charging equipment make and model number for best answers. Also make sure the battery is not allowed to discharge below 12.0 volts while in storage. Float at 13.2 will work well for storage. May need to get a voltmeter to verify actual conditions.
I recommend LFP replacements next time.
The 12 Volt Side of Life
* This post was edited 03/09/23 06:09pm by time2roll *
675w Solar pictures back up
