Grey Mountain
On the rez somewhere in Indian Country
Refrigerator is belly up. Going to replace with a residential model.
Any tips on how to get the existing fridge out of the motorhome?
Thanks.
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
2oldman
NM
Found some vids about Dometic removal.. may be of help.
pianotuna
Regina, SK, Canada
Ummm how will you get the new one in?
Regards, Don
JimR 1
Custer South Dakota
My old Refer went out the large window onto a fork lift or 6 guys on a pickup
New one went in same way.
get lots of help
JimR
Grey Mountain
Looks like out the window is the way to go.
GM
craig7h
Branson MO area
Have you thought about just replacing the cooling unit? I replaced my norcold cooling unit two years ago with a totally 110v system works great. You may want to look into JC Refrigeration products. Its really an easy DIY process. https://jc-refrigeration.com/
Its not getting the old one out but the new one in. A lot of folks have done it so hopefully one of those will help.
Good Luck
Itasca Meridian SE 36g
Road Master Tow Dolly
Grey Mountain
I have a tractor with a front end loader. Looks like through the window is the route to go.
Thanks for the information.
Getting ready to seel the rig.
GM
allbrandauto
maryland
my norcold 1200 went through door of 24 and a half inches by removing norcold front doors installed samsung the same way
Grey Mountain
allbrandauto wrote: my norcold 1200 went through door of 24 and a half inches by removing norcold front doors installed samsung the same way
I will also consider that option.
Thanks.
GM
larry cad
ohio
Grey Mountain wrote: allbrandauto wrote: my norcold 1200 went through door of 24 and a half inches by removing norcold front doors installed samsung the same way
Thanks.
GM
This should work, if you remove the frig doors, and maybe the RV screen door. That worked for mine when I did it.
Our Travel Blog
