RV.Net Open Roads Forum: Tech Issues: NORCOLD Refrigerator Removal
 > NORCOLD Refrigerator Removal
Grey Mountain
On the rez somewhere in Indian Country
Posted: 03/09/23 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Refrigerator is belly up. Going to replace with a residential model.
Any tips on how to get the existing fridge out of the motorhome?
Thanks.
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
2oldman
NM
Posted: 03/09/23 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
Found some vids about Dometic removal.. may be of help.
pianotuna
Regina, SK, Canada
Posted: 03/09/23 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Ummm how will you get the new one in?
Regards, Don
JimR 1
Custer South Dakota
Posted: 03/09/23 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
My old Refer went out the large window onto a fork lift or 6 guys on a pickup
New one went in same way.
get lots of help
JimR
Grey Mountain
Posted: 03/09/23 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Looks like out the window is the way to go.
GM
craig7h
Branson MO area
Posted: 03/10/23 03:36am Link  |  Quote  |  Print  |  Notify Moderator
Have you thought about just replacing the cooling unit? I replaced my norcold cooling unit two years ago with a totally 110v system works great. You may want to look into JC Refrigeration products. Its really an easy DIY process. https://jc-refrigeration.com/
Its not getting the old one out but the new one in. A lot of folks have done it so hopefully one of those will help.
Good Luck
Itasca Meridian SE 36g
Road Master Tow Dolly
Grey Mountain
Posted: 03/10/23 06:00am Link  |  Quote  |  Print  |  Notify Moderator
I have a tractor with a front end loader. Looks like through the window is the route to go.
Thanks for the information.
Getting ready to seel the rig.
GM
allbrandauto
maryland
Posted: 03/10/23 06:25am Link  |  Quote  |  Print  |  Notify Moderator
my norcold 1200 went through door of 24 and a half inches by removing norcold front doors installed samsung the same way
Grey Mountain
Posted: 03/10/23 06:27am Link  |  Quote  |  Print  |  Notify Moderator
I will also consider that option.
Thanks.
GM
larry cad
ohio
Posted: 03/10/23 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Thanks.
GM
This should work, if you remove the frig doors, and maybe the RV screen door. That worked for mine when I did it.
Our Travel Blog
