RV.Net Open Roads Forum: Truck Campers: rear-view camera
 > rear-view camera
jimbow2
LaJunta , co.
Posted: 03/10/23 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Daughter & SIL stopped by our place on there trip, they have a newer Ram & truck camper then we do... Showed me how he setup a "Camera source" rear camera fitted into the p/u screen .... Very impressed.... We have a 2016 Ram & truck camper and reviewing there site appears that perhaps they have units to fit my setup....... so right now b/4 I call "camera source" I'm just reaching out for any of you T/C'ers having experience with after market rear cameras.............. and your advice... Thank You..
jimbow
3 tons
NV.
Posted: 03/10/23 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting…When I first researched RV camera’s I discovered that not all camera’s are equal - some were true RV driving cameras, whereas some were for backing up only…Apparently, the difference is in the camera itself - a back up camera is not designed for continuous viewing due to heat buildup…
Having said that (me having a 16, RAM..), then there’s the question of proprietary camera and wiring harness compatibility, so it would be interesting to know what make and model of camera he used…
3 tons
Tom/Barb
Oak Harbor, Wa
Posted: 03/10/23 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
I liked the camera linked to my phone, put as many cameras as you like on it .
Yeti plus
S.W. Ontario
Posted: 03/11/23 05:20am Link  |  Quote  |  Print  |  Notify Moderator
I have the Camera Source camera on the Bigfoot. I bought the salt spreader version. It has all the wiring to attach right to the truck harness. GM plugs to an aircraft connector with a threaded locking system, to a 10 foot extension, to the camera,which I mounted above the door of the camper. This is on a 2014 Chevrolet Silverado with the OEM tailgate camera. They had the same thing for Ram.
Brian
2014 Chevrolet 3500 CC 4X4 Duramax, Tork Lift Tiedowns, TorkLift Fastguns, Superhitch and supertruss
2009 Jayco 213 SOLD
2008 Bigfoot 25C9.4
jimbow2
LaJunta , co.
Posted: 03/12/23 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
good afternoon...... thanks for reply's.... Question I have regarding rear view cameras>>>. I'm looking for guidance not only backing up in reverse, BUT also as I tow my Geo-tracker or anything else to check while driving will they allow that?????? when T/C is loaded???
Buzzcut1
Norcal
Posted: 03/12/23 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
If the camera i listed as rearview it is designed for full time use, back up cameras are designed for use when backing only.
Some companies make multiple camera systems. I have a 3 camera. one on the back of the camper, one on the back of the horse trailer an one inside the horse trailer to monitor the horse in transit. Mine is by Tadibrothers
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 2019 Lance 1062, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
Tvov
CT
Posted: 03/13/23 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Have you looked into "dash cameras"? Many, if not most, you can buy with a rear view camera. Mine has a wired rear view camera designed to be mounted outside.
Wireless ones are available.
2021 F150 2.7
3 tons
NV.
Posted: 03/13/23 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
I got my Voyager thru RVcameras.com
Oops, meant:
https://www.rvcams.com/
3 tons
* This post was edited 03/14/23 08:14am by 3 tons *
jimbow2
LaJunta , co.
Posted: 03/15/23 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Ordered the " camera source ' to plug in to truck and use the dash monitor of the ram..... will use the flag to see if tracker is coming along......
 > rear-view camera
