Busdriver
Shepherdsville Ky 40165
Have wired smoke detectors in my RV thinking about changing them to battery only detectors only . My ? Is do I just fasten the wire to gather to complete the circuit.
The reason want to change my are eating batteries. Batteries only last about a month
Busdriver 2019 2500 Chevy Duramax , - 2017 Grand Design 303 RLS
nickthehunter
Midwest
If you have two white and two black coming in (total of 4) and the smoke detectors is wired to those two sets of wires, then yes, take the smoke detector wires off, keep the pairs of black and white together by color and cap them off. If the smoke detector is just wired to one set of black and white wires, just remove the smoke detector and cap the ends of the two wires. In other words keep the black(s) and white(s) separate from each other but together by color. If the black and whites touch each other, sparks fly and the breaker pops (hopefully) - that’s a dead short.
Busdriver
Thanks
Bumpyroad
Virginia
my last two smoke detectors in my S & B came with a ten year lithium, no replaceable battery. seems simpler to me.
bumpy
craig7h
Branson MO area
I could be totally wrong on this, but for some reason I remember reading that there are special detectors for RV's. Not saying house ones would not work but for some reason I remember that there was a difference. Might want to check that out.
Itasca Meridian SE 36g
Road Master Tow Dolly
vermilye
Oswego, NY, USA
Just be sure you are replacing smoke detectors, not the propane detector. Detectors that test for gas tend to draw enough current that built in battery versions are rare, which is why they are usually powered by the RV's 12V system.
edited 03/11/23 05:40pm by vermilye *
Jon Vermilye My Travel Blog
My Photo & RV link blog
3 tons
NV.
I got a First Alert smoke detector at Lowes with a built-in non-accessible lithium battery good for 10 years (less than $30) which most likely well outlast me - lol
3 tons
Bumpyroad
Virginia
craig7h wrote: I could be totally wrong on this, but for some reason I remember reading that there are special detectors for RV's. Not saying house ones would not work but for some reason I remember that there was a difference. Might want to check that out.
that sort of rings a bell, don't remember why however.
bumpy
dougrainer
Carrolton, Texas
9 volt battery Smoke detectors are the same for House and RV's. They do not make a special Smoke detector for 9 volt battery operated. That said, I have rarely seen a 12 volt wired smoke detector. COMBO CO and LP 12 volt I have seen. Doug
JimK-NY
NY
Many manufacturers make smoke detectors specifically for use in kitchen areas. They are less prone to false alarms when cooking and they are also a good choice for confined RV spaces which include cooking. I have not seen them advertised for RV use, but they are advertised for kitchen use.
