RV.Net Open Roads Forum: Tow Vehicles: Ram Cummins/Aisin Failures
Search only in Tow Vehicles
 > Ram Cummins/Aisin Failures
Page of 15
Cummins12V98
on the road
Posted: 03/22/23 07:48am Link  |  Quote  |  Print  |  Notify Moderator
FishOnOne wrote:
Cummins12V98 wrote:
Me Again wrote:
Cummins12V98 wrote:
A little more on the "Ball Joints" being bad. My truck is a pavement princess with no off roading no different than the guy in the video. Can't get much easier duty than my truck gets or his concerning ball joint wear.
Wait a minute here, I know for a fact that you drive on California highways all winter and commute North in the spring and South in the fall on I-5 in Northern California, which are similar to "off road" roads in other states.
No lateral stress like off road.
There's a lot of stress on the front end parts when towing a gooseneck/fifth wheel.
Are you kidding????? My 6k pin adds around 175# to the steer axle, THAT will do nothing to cause stress on the front components.
My hitch is full forward to be clear. If this guy adds 100# to his front axle with the RV's he is towing I would be shocked.
If it adds so much stress then my front end should be toast at 102k.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Posted: 03/22/23 09:01am Link  |  Quote  |  Print  |  Notify Moderator
^ Yup
cummins2014
Utah
Posted: 03/22/23 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I too tow pretty heavy no where near what you tow ,but as far as I know my ball joints are good at 70K . Getting my drag link replaced ,whenever that happens . After that is done ,I will get it aligned by an independent alignment shop that only does alignment . I'm sure they check ball joints ,but I will make sure .
Cummins12V98
on the road
Posted: 03/22/23 11:10am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced my front brakes and rotors with EBC. While tire was attached and off the ground I did the push pull top bottom and sides with ZERO slop at 102k.
Why did I replace brakes at 102k??? Because I had a drivers side sticking caliper and inside pad ground into the rotor. So I replaced with OE caliper.
I also removed my ABS sensor and pumped AMZ/OIL grease into the hub assembly. Will be interesting if the hub assembly lasts a long time or not.
FishOnOne
The Great State of Texas
Posted: 03/26/23 10:59am Link  |  Quote  |  Print  |  Notify Moderator
My '12 still has the original driver side hub assembly at 260k miles and had to replace the passenger hub assembly at ~150k miles. They don't have serviceable bearings so pumping grease into the housing is questionable if there will be any benefits.
So far at 260k miles I've replaced the passenger hub assembly and shocks. All other parts on the front suspension is original.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
FishOnOne
Posted: 03/26/23 11:03am Link  |  Quote  |  Print  |  Notify Moderator
No I'm not kidding.
Cummins12V98
on the road
Posted: 03/27/23 08:02am Link  |  Quote  |  Print  |  Notify Moderator
No I'm not kidding.
Maybe you can explain?????
ksss
Eastern Idaho
Posted: 03/27/23 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I have never checked to see how much weight is transferred to the front axle on a gooseneck or RV. That said I run heavy, not so much with the TH but with a gooseneck. I am licensed to 40K and typically right on that in combined weight ('20 3500 DRW). I am struggling to believe that such a small amount of weight is transferred to the front axle. It just doesn't seem possible. The differences between the trailer weight ratings between tag and gooseneck on all the HD OEM's just makes that a leap for me to believe. The way the truck sits when loaded heavy between the two types of trailers says there is more than a couple hundred pounds on the front end with a gooseneck. I don't have data that supports what I am saying, and I probably should have, but when I run over scales which is typically at gravel pits, I just look at gross combined. DOT has not hassled me so I run with that.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
Posted: 03/27/23 09:16am Link  |  Quote  |  Print  |  Notify Moderator
Don’t struggle too much to understand. This discussion has gotten pretty inane.
Huntindog
Phoenix AZ
Posted: 03/27/23 10:01am Link  |  Quote  |  Print  |  Notify Moderator
from tranny failures to ball joints??????????/[emoticon]
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
Page of 15
