RV.Net Open Roads Forum: Is this the biggest/heaviest TC on the market?
 > Is this the biggest/heaviest TC on the market?
Groover
Pulaski, TN
Posted: 03/12/23 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Rugged flat bed TC
"The 2023 Rugged Mountain Denali 3S is a hard side, triple-slide, dry bath truck camper made for long bed trucks. The interior floor length of the 2023 Rugged Mountain Denali 3S is 12’7”, the interior height is 6’8”, and the center of gravity is 64” from the front wall.
The Denali 3S has an 80-gallon fresh tank, a 77-gallon grey tank, a 35-gallon black tank, and a 6-gallon water heater. It can accommodate up to ten Group 27 batteries and has two 20-pound propane tanks.
Rugged Mountain is reporting the base weight of the Denali 3S at 5,538 pounds. The cost of the 2023 Rugged Mountain Denali 3S is $74,900."
Base price is $74,900. You can option it up to $125,000. 5500 series truck recommended as dry weight is 5,538lbs. Why not go for the F600?
It is a beautiful rig but it is a monster! I used to think that my old 12'6" bed length TC with no slides was large and heavy at 3,500lbs
Photomike
Southern Alberta or where the camper is parked!
Posted: 03/12/23 12:54pm Link  |  Quote  |  Print  |  Notify Moderator
I wonder how this will ride on a Tacoma??
2017 Ford Transit
EVO Electric bike
Advanced Elements Kayaks
jimh406
Western MT
Posted: 03/12/23 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
Advertisement aside, it will be interesting if it holds up with that wood structure held together by spray foam.
Also, I wonder why they put the center of gravity so far back. With a base weight of 5,538 lbs, and ten Group 27 batteries, it seems they don't think the laws of physics apply to them at all.
Kind of a shame that other than the wood frame, there doesn't seem to be any innovation in the design, but maybe I missed something.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
Posted: 03/12/23 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Idk about a Taco but a Hilux would hold up! Lol
Posted: 03/12/23 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
What’s wrong with wood frame? Can’t say there’s an appreciable difference either way.
Kinda agree on the Cog although it probably wasn’t really an option to get it more front heavy.
But you’re right, it’s designed to only fit on a 60” CA truck. So that puts the cog almost a foot behind the rear axle.
Regardless I have trouble finding value in a $100k slide in camper. Hope for the mfg that others don’t.
Posted: 03/12/23 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
By the time you buy a decked out Denali or Mammoth and a hot rod fancy 5500 to match it, you’re firmly in the 4wd SuperC range. It’s a limited market for sure.
Apparently EC and Host sell more than they can make or it wouldn’t make sense to get into building these.
notsobigjoe
southeast
Posted: 03/12/23 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
Mike I spit my coffee... LOL
monkey44
Cape Cod, MA and Central Fla
Posted: 03/12/23 04:13pm Link  |  Quote  |  Print  |  Notify Moderator
Nope, you'll need a Tundra for this baby ... [emoticon]
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
brain
Muscatine, IA
Posted: 03/12/23 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
The spray foam is a nice idea for structure, but it's much better if you put the structure together first and then press it into a mold and then inject foam into the voids from the ends. They do similar for structural panels for houses (called SIP panels, we've long considered building a house from them).
I also concur on the innovation angle. For the price, I'd grab a Okanagan 126TKS (I think Eagle Cap makes a follow on version, or did), which has the same interior space, does not require a flat bed truck. Both still require a 550/5500, but I rather like the idea of having a regular truck bed when the TC is not on.
Jim
dodge guy
Bartlett IL
Posted: 03/12/23 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
$75 k plus another $120k for a truck? For $200K I’ll just buy a super C on a Ford or Ram 4X4 chassis.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
