RV.Net Open Roads Forum: Is this the biggest/heaviest TC on the market?
 > Is this the biggest/heaviest TC on the market?
deltabravo
Spokane, WA
Posted: 03/12/23 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
The next heaviest was probably the Arctic Fox 1163 Triple Slide.
BigSwick
FL
Posted: 03/13/23 02:33am Link  |  Quote  |  Print  |  Notify Moderator
How is the camper attached to the truck bed? I see what may be small tiedowns on the front, but they don't look big enough to keep it in place,and nothing in sight for the rear.
Posted: 03/13/23 04:26am Link  |  Quote  |  Print  |  Notify Moderator
brain wrote:
The spray foam is a nice idea for structure, but it's much better if you put the structure together first and then press it into a mold and then inject foam into the voids from the ends. They do similar for structural panels for houses (called SIP panels, we've long considered building a house from them).
I also concur on the innovation angle. For the price, I'd grab a Okanagan 126TKS (I think Eagle Cap makes a follow on version, or did), which has the same interior space, does not require a flat bed truck. Both still require a 550/5500, but I rather like the idea of having a regular truck bed when the TC is not on.
Jim
How many class 5 trucks with a “regular bed” around?
GTO66
Posted: 03/13/23 09:36am Link  |  Quote  |  Print  |  Notify Moderator
If it had a welded aluminum frame maybe. My alpenlite is 23 years old and going strong and I'LL its aluminum frame is a big part of that. The weak part is the rear wings, which i rebuilt with PT wood no issues since. Not sure the cost of a 5500 truck but 200k total wood be my guess.
Posted: 03/13/23 10:21am Link  |  Quote  |  Print  |  Notify Moderator
My 20 year old AF wood framed camper seems to be doing just fine, last I checked.
Sold it a couple years ago but as of last summer the only issue the new owner has had was another sticky jack.
Camper_Jeff_&_Kelli
Seattle
Posted: 03/13/23 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I know early on, S&S tried to make a slide out TC, Dinette only, and it had structural issues with the wood framing. They stopped making it after a couple years. Since this beast is going to be on a flatbed, it should be fully supported and not be subject to the same issues as a standard TC. With the weight and size of this model, I would think it to be prudent to install a few Simpson Z-MAX steel connector brackets in the most stressed points of the framing like corner walls and the cabover. It looks like it has decent solar, I would prefer about 600 AH LIFEPO, 3x200AH batteries in there and a 3000 watt Victron or Xantrex inverter charger to run electrical appliances and AC possibly in the form of a mini split. In our case, I could do without the rear couch bed area and convert it into a wardrobe, shelves, and pantry. Everybody has different needs. I'd also consider installing windows in the side wall of the slides. Something else I treasure on my current setup is the cab/TC passthrough. The cats love it and I can squeeze up into the truck in case of an emergency. It's not a friendly design for OffRoad and rougher terrain with the length of the rear overhang sticking out the back. For someone who's going to stick to the main roads and well maintained gravel roads, it's going to be a great home or home away from home.
Camper Jeff and Kelli's Blog!
CITAP1 Jeff's YouTube Channel
A CLOSED MOUTH GATHERS NO FEET!
RobertRyan
Australia
Posted: 03/27/23 02:48am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Photomike wrote:
I wonder how this will ride on a Tacoma??
Idk about a Taco but a Hilux would hold up! Lol
HaHa yes it would
