RV.Net Open Roads Forum: Fifth-Wheels: 2014 puma 356qlb
 > 2014 puma 356qlb
smadden210
Whitehouse
Posted: 03/12/23 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
I apologize if this has been covered before. I am new new new to the 5th wheel community.l and over 20 years since having a camper in general. My slide out does not work on my csmper and i am looki g for ideas to search out. Ive replaced the switch to operate the slide out just for kicks, also put a good battery in because it says "battery hook up required for slide out operation" i do not get any clicking, or any sound, any slight movement...etc, etc...i get nothing. Can someone PLEASE tell me what else to try or do? Camper is still mounted to truck if that matters.
dedmiston
Coast to Coast
Administrator
Posted: 03/13/23 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Good Sam Club to Fifth-Wheels.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
MFL
Midwest
Posted: 03/13/23 03:11pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check for power at the switch, when switching out? Do you have a battery disconnect switch? Also check solenoid breaker, not far from battery, usually on inside basement wall. If you have a meter to check voltage, follow the power where you can, to confirm.
Did you hook battery up correctly, to not blow reverse polarity fuse?
Good luck, welcome to the forum!
Jerry
fj12ryder
Platte City, MO
Posted: 03/13/23 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Is this an electric slide, or a hydraulic powered one?
Howard and Peggy
"Don't Panic"
 > 2014 puma 356qlb
