RV.Net Open Roads Forum: Truck Campers: LiFePO4 Converter Change?
 > LiFePO4 Converter Change?
Ranger Tim
Idaho
Posted: 03/13/23 09:17am Link  |  Quote  |  Print  |  Notify Moderator
I just want to switch from lead acid to lithium, not upgrade wires and everything else. Finding a new replacement board for my WF-8955PEC seems to be complicated. Straight 14.6V continuous boost single phase vs. 14.6 boost and 13.4 idle dual phase approach, some have a switch for LA/Li, others are auto sensing, still others are Lithium only. Huge range of prices indicates there may be some poor quality fake/unauthorized parts out there. I don’t want to replace the entire thing, just the converter section.
Reading forum posts from many sites usually ends in discussions that go into the weeds quickly. Can anyone cut through it and keep it simple?
Ranger Tim
2006 F-350 Super Crew King Ranch SRW Bulletproofed
2016 Wolf Creek 840
Upper and Lower StableLoads
Posted: 03/13/23 10:31am Link  |  Quote  |  Print  |  Notify Moderator
This one will as well. On another note I’m surprised Northwoods put that junk converter in it.
time2roll
Posted: 03/13/23 11:08am Link  |  Quote  |  Print  |  Notify Moderator
First of all 14.6 is generally the peak maximum to subject the battery to. Most of the converter manufacturers get this wrong. 14.2 - 14.4 volts is better. 13.2 - 13.4 is fine for float. Some even hold 14.6 indefinitely and is very bad for lithium.
Consider the existing WFCO may work fine. Otherwise a standard Progressive Dynamics is better.
www.bestconverter.com/PD4655MBA-WildKat-55-Amp-Main-Board-Assembly-for-WFCO-8955
675w Solar pictures back up
Ranger Tim
Idaho
Posted: 03/13/23 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
WFCO makes an auto-sensing replacement kit that is two stage. I think I’m gonna order it.
pianotuna
Regina, SK, Canada
Posted: 03/13/23 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
Ranger Tim,
14.6 is right on the edge of too much. 14.4 volts may increase life span.
Regards, Don
bighatnohorse
Cave Creek
Posted: 03/14/23 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Sure.
This one: https://www.amazon.com/gp/product/B07DP3........_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Remove old, replace with new. Plug and play. 14.4 volts max charge.
You're done.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity."
-Yeats
WarrenS65
SoCal
Posted: 03/17/23 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Your lithium will also have a max and recommended charging amperage. Make sure the charger doesn't exceed this.
2022 F450
2022 Host Everest
2021 Yamaha YXZ1000R
1987 Honda TRX250R
2002 Honda 400EX
1998 Yamaha Warrior
2006 Yamaha Raptor 250
2018 Look 24' enclosed trailer
Posted: 03/17/23 09:47am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Ranger Tim,
Yet even the beloved and revered Battleborn recommends up to 14.8. And says 14.4-14.6 is reccomended.
How much lifespan will be lost charging at 14.6 vs 14.4?
(Hint…this is another non issue that you’re trying to confuse the OP with…)
Posted: 03/17/23 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Don’t. Unless you know something about WFCo we don’t. Traditionally they are borderline junk.
StirCrazy
Kamloops, BC, Canada
Posted: 03/18/23 08:58am Link  |  Quote  |  Print  |  Notify Moderator
and your being nice [emoticon]
I won't have WFCO in anything I own anymore. the last three units I have had they were ripped out and changed to PD before they left the lot. I do have a couple WFCO's laying around though.. I use them to power my 12V winch in the garage...
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
