RV.Net Open Roads Forum: Tow Vehicles: F-250 vs F-350 srw
Search only in Tow Vehicles
 > F-250 vs F-350 srw
JnJnKatiebug
NW Arkansas River Valley
Posted: 03/14/23 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Don't pay any attention to my signature, I have not changed it. Just throwing this out there and I know some will want to beat me up so fire away. I do not want a dual wheel pickup for a daily driver and I do not want an extra vehicle. Here is my setup and my weights. F-250 diesel, short bed crew cab, 7,500# air bags. Jayco Pinnacle with MORride pin box. I looked at the F-350 srw and the axle ratings are the same, 5200# front and 6340# rear. Springs are the only difference, hence the airbags. 20 inch Michelin tires rated at 3750# each for a total of 7500# per axle.
Loaded to travel the scale ticket says, front axle 4,640#, rear axle 6,900#. So I am ok on everything except rear axle and it is 560# over the rating. I have been running this setup for 2 years. It drives and rides like a dream, no bouncing, no bucking, no chunking and it stops almost as quick as the truck by itself. It will go faster uphill than I want to go. We went all over Colorado last year (including the million dollar highway) and not once did it feel unsafe. I guess time will tell what the 560# over on the rear axle will do.
2016 Chevy Tahoe
2017 Flagstaff 26FKWS
(Picture in profile)
"The best things in life are the people you love, the places you've seen,
and the memories you've made along the way".
ford truck guy
Pennsylvania
Posted: 03/14/23 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
You state that the F350 RAWR is 6340 on the 350?? my F350 is 7240#
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
JnJnKatiebug
Posted: 03/14/23 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
Is it a srw or dwr?
JnJnKatiebug
Posted: 03/14/23 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Is it a srw or dwr?
I was told the the srw are the same.
MFL
Midwest
Posted: 03/14/23 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
^ Agree, a late model 350 should be rated more than 7K, rather than same as 250.
While a 350 would be best choice, if buying new, I'm sure your 250 works well too, as it has, with the use of bags.
Jerry
ford truck guy
Pennsylvania
Posted: 03/14/23 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Is it a srw or dwr?
SRW
ford truck guy
Pennsylvania
Posted: 03/14/23 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Is it a srw or dwr?
The dealer tell you that? Prolly didn't have a 350 on the lot to upsell..
gme3470
Redding, CA
Posted: 03/14/23 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
The rear axle rating on our SRW 2022 F-350 XLT4x4 is 7230. The F-250 specs show 6340 for same year.
2022 F350
Nash 25C
JIMNLIN
Oklahoma
Posted: 03/14/23 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Fords F350 srw has a 6340 rawr....6780 rawr...7230 rawr depending on wheel sizes and other selections.
Fleet Ford specs shows the F250 uses the same 6340 as the F350 srw.
Also the F250 6.7 diesel uses the same rear spring specs as the F350 srw.
Fords Sterling axles are rated well above the OP 6900 rear axle weight plus a upgrade to higher capacity 20" wheels and tires.
Sounds like the OP has done his home work.
4x4ord
Alberta
Posted: 03/14/23 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
The F250 diesel with the Trailer Tow High Capacity is the same truck as the SRW F350 diesel with almost identical price tags as well .... the F350 is $335 more than the F250. What was your reason for choosing the 250 over the 350? Has yours got the High Capacity Trailer Tow package?
2022 F350 SRW Platinum short box 4x4.
B&W Companion
