RV.Net Open Roads Forum: Tech Issues: SeeLevel tank monitor system
 > SeeLevel tank monitor system
Cptnvideo
Arizona - most of the time
Posted: 03/14/23 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
I hate our empty, 1/3, 2/3 and full tank monitors (which frequently lie).
I'm looking at (and probably purchasing) the 4 tank level monitor made by Garnet Instruments. It will monitor our fresh, galley, gray and black tanks using external stick on sensors that read out in percent of full.
Does anyone have any experience with the Garnet Instruments SeeLevel tank monitors?
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
ktmrfs
Portland, Oregon
Posted: 03/14/23 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
yes, I've had it on our outback for almost 10 years. it's easy to install, uses the same wires as the usual cheap factory guage. It is consistent and repeatable even on the black tank. The ONLY time I've had it be the least bit suspect on readings is if the galley tank ends up with a bunch of soap suds after washing dishes. It may read high for 30 minutes or so.
There is one downside to the system. the scale ASSUMES a completely rectangular tank. so for your fresh water the % reading is very accurate. for black/grey tanks that have a sloped bottom or irregular shape, it will show it filling faster than it really is.
However, there is an easy solution. Ours reads in 10% incremennts. what I did is useing a flow meter on a hose, filled the black and grey tanks and at each 10% increment noted how much water (gallons) was at that level then made a "cheat sheet" I post next to the tank. So in my case, 32 gallon tanks, 50% on the meter has the tank filled to about 12 gallons IIRC. so my sheet shows 20 gallons for remaining capacity.
Ours is for 4 tanks, fresh, grey, galley, black along with switch for pump.
Measure your tank height first, then pick the guage that best fits the tank height and gives you the best resolution.
Once installed you may find like I did that 100% isn't completely full, the top of the guage must be slightly below the top of the tank. I just noted the remaining capacity in gallons with the tanks read 100%, but in the end I like that because now when a galley tank reads 100% I know I have 5 gallons capacity remaining before I run into trouble. likewise for the grey and black.
2011 Keystone Outback 295RE
3 tons
NV.
Posted: 03/14/23 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Wouldn’t ever be without one, when off grid saves an unwarranted trip to town !!
3 tons
Cptnvideo
Posted: 03/14/23 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, Gents. I will be buying.
deltabravo
Spokane, WA
Posted: 03/14/23 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
YEP!
I installed it in 2011 on my Arctic Fox Truck Camper. It worked flawless. I kept the monitor panel and bought new tank sensors and installed it on my AF 992 in 2020 when I sold the 811 and bought the 992.
IT IS AWESOME!
ktmrfs
Portland, Oregon
Posted: 03/14/23 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
yup, as I mentioned in a previous post, the only improvement I would like to see is a way to calibrate the meter for odd shaped tanks. e.g. typical grey/black tanks that have a slopped bottom. calibration assumes a rectangular tank, But then once you have used it a few times, you'll get familiar with it.
It is a well made, well thought out, solution to the factory sensor system.
There is another system (don't remember the name) that let's you do a calibration for odd tanks, but it's much more complex installation, doesn't use the typical facgtory wires, and is even more expensive.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 03/14/23 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
I had SeeLevel gages installed on my DP and they weren't a bit better than the OEM gages. They were a waste of money.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
StirCrazy
Kamloops, BC, Canada
Posted: 03/15/23 07:43am Link  |  Quote  |  Print  |  Notify Moderator
I know a few people who have them and they are the next "upgrade" project on my camper as it has no guages whats so ever and it drives me nuts having to guess when tanks are full haha. but ya out of the 4 or 5 people I know who have them, they all love them. there is the issue with weird shaped tanks but it isn't bad, for them the bottom filles faster but the top fills slower so it still works for them. the other issue is the inbetween hight tanks so where its to tall for one sender but to short for two, so they just skew it towards the top of the tank so they know when it is full. but I see they have a new sender out that looks like it addresses that issue. I'll have to see what else has changed.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
12thgenusa
Loveland, Colorado
Posted: 03/15/23 09:00am Link  |  Quote  |  Print  |  Notify Moderator
I've had mine for over ten years. Works great. I can add about 5 gallons to the fresh water tank after it reads 100% and there are probably 5 gallons left after it says empty. The readings jump in 6% increments.
2007 Tundra DC 4X4 5.7, Alcan custom rear springs, 2009 Cougar 245RKS, 370 watts ET solar,
Rogue MPT-3024, 440 AH GC2 bank, ProWatt 2000,100% LED lighting
Cptnvideo
Posted: 03/15/23 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I've done a little more research. There are 2 stick on sensors available and they are stackable. They work on tank height of 3.5" to 26". According to Grand Design, my 4 tank heights vary from 7.75" for the fresh tank to 8.75" for the 3 holding tanks.
The sensors can be trimmed with scissors to accommodate different height tanks. The manufacturer suggests a 1/2" gap at top and bottom of tank due to the extra thickness at those points.
* This post was edited 03/15/23 02:09pm by Cptnvideo *
