3 tons
NV.
Trackrig wrote: I had SeeLevel gages installed on my DP and they weren't a bit better than the OEM gages. They were a waste of money.
Bill
Not better than OEM, really??… Perhaps your angst should be directed towards your installer??
3 tons
ktmrfs
Portland, Oregon
Cptnvideo wrote: I've done a little more research. There are 2 stick on sensors available and they are stackable. They work on tank height of 3.5" to 26". According to Grand Design, my 4 tank heights vary from 7.75" for the fresh tank to 8.75" for the 3 holding tanks.
The sensors can be trimmed with scissors to accommodate different height tanks. The manufacturer suggests a 1/2" gap at top and bottom of tank due to the extra thickness at those points.
one trick is to pick the optimal sensor, the ones that will give you a nice increment in level adequate for your needs. In my case I was able to pick a sensor length that gives me readout in 10% increments.
Since the system is reasonably spendy, before I ordered I'd open up the bottom and actually measure the tank height where you are going to install the sensors, likely near the existing sensors.
To close to the top and it won't read 100%, to far down and 100% won't be full. Trick is to tape them on and find a happy medium, in my case for the black/grey/galley one where 100% reading was really around 90%, was close to the top, but didn't want to push it more. And for the fresh where 10% still had enough for a quick shower, washing some dishes etc. Not low enough that at 10% I would risk running out of water.
2011 Keystone Outback 295RE
Cptnvideo
Arizona - most of the time
Understood, ktmrfs. I measured the 2 tanks that are accessible behind the pass thru compartment. And I called Grand Design & got drawings & specs for all 4 tanks.
I will be ordering the 9" sensors, cutting 1" off the 3 holding tank sensors and 2" off the fresh tank sensor.
Also, I believe the new units read in 1% increments. The picture of the display unit shows 78%.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
