DC&MC
formerly of Keizer Oregon USA
We bought a 50 watt solar panel to put on our batteries when in storage. Today we went and checked it after two days hooked up and the wires by the controller were all melted! Why would this happen? We were clamped to positive and negative correctly. We were clamped to one of the brand new 12 volt batteries that we had just installed. Nothing at all was running in the motorhome when we were clamped on.
2006 Mandalay 40E motorcoach
2017 Ram PU
2017 Harley Road King
Home base Yuma AZ
ktmrfs
Portland, Oregon
no way a 50W panel would have enough current to melt the wires. Max current would be on the order of 4 amps, most likely in the range of 3A from a typical PWM controller. even 20ga wire can handle 3 A continous,
My guess is that the issue is with the connection to the battery, and it was reversed, damaged the controller, caused a overcurrent in the cables.
However, the controller should have protected against reverse hookup w/o any damage.
So.... w/o more info puzzling.
2011 Keystone Outback 295RE
larry cad
ohio
Was it a real bright sunny day?
Our Travel Blog
ppine
Northern Nevada
Reverse polarity is the usual culprit with melted wires.
CA Traveler
The Western States
i'd guess the controller has a short or if no controller the panel is shorted.
For a followup check the panels Voc and Isc to be sure it's OK. Then reconnect with new wires and check V and A on the battery wires.
2014 Grand Cherokee Overland
Bob
KD4UPL
Swoope, VA
Clamps are a poor means of connection. Bad connections cause heat. However, that little panel shouldn't generate enough current to make much difference.
Did you install a fuse on the positive cable near the battery? It should have one to prevent this sort of thing.
Do you have a charge controller or did you just hook the panel straight to the battery? You really should have at least a basic charge controller to keep the battery from being over charged.
I'm going to guess a cheap solar panel that shorted out with no fuse or charge controller to protect it.
ktmrfs
Portland, Oregon
KD4UPL wrote: Clamps are a poor means of connection. Bad connections cause heat. However, that little panel shouldn't generate enough current to make much difference.
I'd say cheap fuse..... a length of 20ga or so wire as a fuseable link!!!! something shorted in the panel and the battery tried to light it up!!
