Seabass69
2004 HR scepter, the front brakes like to lock up hard if you have to use ter brakes very hard. dry ground or wet they will lock and slide quickly.... any ideas on what to look at first? Maybe just as simple as new pads on rotors on the front?
Thanks
enblethen
Moses Lake, WA
What type of brakes? are they air over hydraulic?
Air over hydraulic could have moisture in the system.
New calipers and good bleeding of system.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
wolfe10
Yup, let us know:
Disk or drum?
Hydraulic or air?
And, at 19 years old, what maintenance has been done on them?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Seabass69
Air brakes for sure, disc, and I can only assume they original. Where’s does one get brakes parts for a diesel pusher? I’ve done many brake jobs on normal cars and trucks but I have never bought brake parts for a motorhome….
enblethen
Moses Lake, WA
Do you know what chassis it is on?
Seabass69
Roadmaster I believe
enblethen
Moses Lake, WA
I would check with your local NAPA
wolfe10
And, if floating caliper disk brakes, check that the pins (that the caliper floats on) are clean and lubed.
Pretty easy for dirt, rust, etc to not allow the "lazy pad" to pull away from the disk.
Since it is "air brakes for sure", no worries about changing brake fluid.
enblethen
Moses Lake, WA
Need make sure that the air gets drained from tank. Caliper pistons could be rusted.
How long has it been sitting?
oldave
Tx
Are you sure it's disc? My 03 Monaco has drum brakes all around & yours is a Monaco too.
