RV.Net Open Roads Forum: Class A Motorhomes: Brake Issue
 > Brake Issue
Seabass69
Posted: 03/16/23 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Need make sure that the air gets drained from tank. Caliper pistons could be rusted.
How long has it been sitting?
it doesnt sit much, just a little over the winter but this problem was there last year
Seabass69
Posted: 03/16/23 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
oldave wrote:
Are you sure it's disc? My 03 Monaco has drum brakes all around & yours is a Monaco too.
it is disk, air pod on the caliper itself
Stim
NE Florida
Posted: 03/20/23 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Could be a defective relay valve not releasing or operating slowly. ??
Maybe a kinked air hose. ??
With MH stopped, press hard on brake peddle then release and listen for the air to exhaust. Is it instant or time release?
I've worked on hundreds of air brakes on semi's but got out of it before disc came out so I'm guessing a lot.
It should have standard generic air brake parts available at large truck parts stores.
Ray,IN
IN, USA
Posted: 03/20/23 10:38pm Link  |  Quote  |  Print  |  Notify Moderator
Check for water in tanks, if water is allowed to remain in tanks it can get into the braking system, which gets expensive to repair.
When was the air dryer filter last replaced?
2000 Winnebago Ultimate Freedom pushed by a 2013 Chevy Silverado K1500 And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
oldave
Tx
Posted: 03/21/23 08:47am Link  |  Quote  |  Print  |  Notify Moderator
Many/most brake systems have a proportioning valve that regulates the pressure front to back. I can't say for sure you have one but you probably do.
Your symptom sounds like the rear brakes are not getting their share of air pressure IMHO.
Google & see what they look like.
Seabass69
Posted: 03/22/23 06:09am Link  |  Quote  |  Print  |  Notify Moderator
I bought it 2021 and replaced it then, may need to again.. thanks
Seabass69
it sounds normal to me but I will look into that, thanks
Seabass69
Posted: 03/22/23 06:10am Link  |  Quote  |  Print  |  Notify Moderator
thanks
Ray,IN
IN, USA
Posted: 03/22/23 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
For trucks with air brakes the dryer filter must be replaced annually, but for our infrequent MH use every 5 years is adequate.
 > Brake Issue
