RV.Net Open Roads Forum: Tech Issues: Norcold N611 AC circuit
 > Norcold N611 AC circuit
RVhiker
Posted: 03/16/23 09:19am Link  |  Quote  |  Print  |  Notify Moderator
I have an N611 Norcold refrigerator in a 2011 Jayco fifth wheel. The refrigerator has always cooled well both on AC and propane, and does not have any telltale yellow signs of leakage in the cooling system.
However, now the refrigerator will work only on gas. When the trailer is plugged into a 20 amp circuit at my house, with a ground fault detector in the house circuit, the ground fault detector turns off the electricity to the trailer. I have tested the AC circuit in the refrigerator by not having any other AC used in the trailer, including the power converter; and until the refrigerator AC circuit was plugged in, the Progressive Dynamics PMS shows 0 AC amps. When the refrigerator AC circuit was plugged into the trailer 120 volt system the ground fault interrupter on one house circuit cut the power after about 30 seconds, and on a separate house circuit (with another ground fault detector) in about 5 minutes.
What are my options?
There's lots of advice and information in forums...
sometimes it is correct.
2011 Jayco 28.5RLS; 2008 Chevy 2500HD Crew Cab; Duramax/Allison; Pullrite 14k Superglide Hitch
trailrider
Idaho Is Full! Don't Move Here!!!
Posted: 03/16/23 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like the heating element in the fridge is bad.
2020 Chevrolet Silverado 3500HD GAS!!!
1978 Chevrolet Silverado K20 4x4
2007 Komfort 277TS
2020 Sherco 300 SEF Factory
2018 Honda Rancher TRX420FA6
2017 Montesa 4RT260
2021 Honda CRF450X
dougrainer
Carrolton, Texas
Posted: 03/16/23 09:56am Link  |  Quote  |  Print  |  Notify Moderator
You have a Heater Element with an imbalance of current draw. On a NON GFCI circuit the element would work OK. Just replace the 120 element. Doug
RVhiker
Posted: 03/16/23 10:43am Link  |  Quote  |  Print  |  Notify Moderator
What's involved in replacing that heating element? I am rather capable in repairing most things and am not intimidated in repairing anything if I have the tools to do it and some knowledge (or instructions) about how to do it.
CloudDriver
New Jersey Shore
Posted: 03/16/23 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
Link for Norcold service manual below. See page 37 for location of AC heater element.
http://bryantrv.com/docs2/docs/ncoldnnewnseries.pdf
2003 Winnebago Minnie 24F - Ford E-450">
pianotuna
Regina, SK, Canada
Posted: 03/16/23 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
In the mean time--a work around is to plug the fridge into an inverter--then power the inverter from the converter.
Regards, Don
RVhiker
Posted: 03/17/23 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Yesterday, I noticed a problem with the romex that supplies the AC outlet in the refrigerator's outside access. A small loop of the romex was pressing slightly on a fairly sharp edge of a galvanized sheet metal brace that supports the sheet metal piece that the controls and etc of the refrigerator are mounted to. I looked at the romex, and there is a dark, sharp dent in the plastic outer jacket, maybe leaking current to the sheet metal bracket. I pulled the loop of romex away from the edge, wrapped the dent in electrical tape, and the AC refrigerator heating element is still working since then. I think that fixed the problem.
The link to the Norcold Service Manual is much appreciated.
Thanks to all for the electrical information and the willingness to help!
dougrainer
Carrolton, Texas
Posted: 03/17/23 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update. I MISSED where you stated HOW it tripped. A defective Heat element would NOT trip a GFCI unless the refer was turned ON to 120 power. Doug
wnjj
Cornelius, Oregon
Posted: 03/17/23 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
It certainly could. The neutral side of the element is not switched and if it comes into contact with a grounded surface, the GFCI will trip even with the fridge turned off. This is no different than the neutral portion of the supply Romex touching ground.
GFCI's detect a difference between hot and neutral current OR a short between neutral and ground with no power flowing.
