RV.Net Open Roads Forum: Class B - Camping Van Conversions: Spare tire size
kbunning
Colorado
Posted: 03/17/23 07:23am Link  |  Quote  |  Print  |  Notify Moderator
2018 MB Sprinter/WB Revel - running upgraded 245/76/R17 wheels/tires, but my spare is 245/76/R16. Will I be ok if I have to drive a short distance using this spare? We are headed to Alaska and plan to drive somewhat remote, gravel roads. I would just use the spare to get us to a tire shop.
CA Traveler
The Western States
Posted: 03/17/23 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Find out what the mfg says about 1 different sized tire on a 4x4. It is a 4x4 correct?
First and foremost there are many Alaska trip areas where there is no tire related shop for many miles, think hundreds. This can/does also include most of Canada. Plus when you get they may not have your size and getting one could take days.
My advice is be prepared. Take one full sized mounted tire and consider a unmounted spare for extra caution. And note that even the same sized tire may not have the same diameter due to wear or other differences due to brands so that could be a consideration for longer distances.
Our round trip mileage was 9600 miles.
2014 Grand Cherokee Overland
Bob
ernie1
Sacramento,California,USA
Posted: 03/17/23 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Been there done that. If I were to do it again, I would carry a full sized spare that matches the others on the vehicle and also a GOOD tire plug kit. Don't get the cheapies that are for temporary use. Wish I could remember the name of the one I bought but mine has a metal tip for insertion, does not require any vulcanizing material and is considered a permanent fix. If you're not comfortable that it is a permanent repair, it will at least get you a very long distance to a repair shop. Oh also, get a good 12v compressor to air your tires back up. One the best is sold by Viair. Plugging the tire allows you to do a quick and easy repair without having to remove the flat tire and mount the spare.
When we were in Alaska, there were places out in the sticks that you wouldn't want to be in the process of changing a tire and have some critter pay you a visit.Good luck have fun!
time2roll
Posted: 03/17/23 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
Contrary to most I would go as is. Next time a tire is purchased get the spare replaced.
675w Solar pictures back up
