RV.Net Open Roads Forum: Recommend Good E-450 Dash AC Repair, SoCal
 > Recommend Good E-450 Dash AC Repair, SoCal
Bordercollie
Garden Grove, CA, USA
Posted: 03/17/23 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
Our 2004 Fleetwood Tioga 26Q has a dash AC problem, the vacuum actuator is not working to divert cold air through the dashboard vents. This is caused by a leak in a vacuum hose that is located in the rear of the engine. There are a number of "band-aid" fixes to bypass the problem but I want the fix done right by an expert AC repair man. I am 84 and unable to do the work myself. If any of you have had the same problem and had it fixed by a good AC repair place, please give me a recommendation. I live near Disneyland.
Chum lee
Albuquerque, NM
Posted: 03/18/23 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Assuming this is a 26' Class C MH on a Ford E-450 chassis, my first call would be to Tom's Truck Center. (formerly Carmenita Ford in Santa Fe Springs) They won't be the cheapest place in town and they may no longer work on Ford MH's that old, but the call is free and it's local to you. It's a place to start. Google is your friend.
Chum lee
IAMICHABOD
Sunny So Cal
Posted: 03/18/23 08:25am Link  |  Quote  |  Print  |  Notify Moderator
I have been going to a local garage for years to have my RV worked on.
Their work is outstanding and they do everything including A/C service.
Not cheap but everything comes with a 2 year warranty,you might give them a call and see what they say.
They are located in Bellflower, Ray A Motive
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Bordercollie
Posted: 03/18/23 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Ichabod, Good idea, took rig to them for major servicing some time ago, will give them a call.
30sweeds
Iowa
Posted: 03/22/23 06:59am Link  |  Quote  |  Print  |  Notify Moderator
The "band-aid" fix I use is a permanent repair using all factory parts,replacing the failure prone poorly designed original setup.
Bordercollie
Posted: 03/22/23 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
The problem of no air/AC flow through dash vents is fairly common on older E-450 RV conversions. Plastic vacuum tubing hardens and cracks from engine heat and aging. Tubing should be replaced by good rubber tubing. There may a cracked vacuum tank, and other possible problems. I suspect that vacuum leak may cause a problem with smog test readings and general engine performance. It looks like later E-450 conversions use an accessible add-on electric vacuum pump to avoid this problem.
tomcat88
prescott valley
Posted: 03/22/23 04:38pm Link  |  Quote  |  Print  |  Notify Moderator
This is a problem on all E-150 thru E-450, the Ford dealer wanted $1500. to $2000.00 to fix my 04 E-450, So I check out some You tube videos and went to NAPA pick up some good rubber vacuum tubing and vacuum control valve for the AC, took me 45 minutes to do the repair. No I did not remove the right inner and outer fender, all of the dash like Ford would, only the grove box and dash cover under it. I was 77 when I did the repair,
cbigham
orange , CA
Posted: 03/24/23 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Fullerton Ford. Straight people. Carmelita not the same since Tom's took over.
Chum lee
Albuquerque, NM
Posted: 03/25/23 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
cbigham wrote:
Fullerton Ford. Straight people. Carmenita not the same since Tom's took over.
Good to know. Years ago, (Carmenita Ford) if you had a larger Ford truck, was the best place in the LA/OC area. Thanks for the update.
Chum lee
fourthclassC
MA
Posted: 04/07/23 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Just a quick summary of my experience with this. I went the route of bypassing the vac. accumulator and check valve with Ford OEM parts. Plenty of space to mount the new accumulator. and easy to replumb with new good vac hose. Not really mickey mouse at all. Just a bypass scheme well hidden by the dash panel.
