RV.Net Open Roads Forum: Towing: Trailer Brakes Not Staying On
Search only in Towing
Open Roads Forum  >  Towing
 > Trailer Brakes Not Staying On
Emolsee
Reno
Posted: 03/17/23 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Our travel trailer just started loosing brakes as we travel. A couple of days ago I lost the trailer brakes a couple of hours into or drive. That night I noticed that the plastic pin that connects to the emergency disconnect trailer brake box was melted. I replaced the whole breakaway brake box setup and plugged the trailer brakes in and it looked like they were working. Then the next day, about an hour into the trip the brakes stopped functioning again. I stopped and crawled under the trailer to check all the connections I could find. I noticed that pulling the pin on the emergency break away brake box and putting it back in made my trailer brakes function again. But after 30 minutes or so the break controller in the tow vehicle will start flashing again letting me know that the trailer brakes aren’t working. Sometimes they cycle back and forth from functioning to not functioning over 30 minutes or so, but they usually end up not working and an be cycled back on by pulling the trailer emergency disconnect plug and then putting it back in. But the brakes do not stay on. Could this be a problem with the controller? I do not understand the connection with the break-away break pin and why that would make the brakes function for a while.
eHoefler
ozark mountains
Posted: 03/18/23 05:09am Link  |  Quote  |  Print  |  Notify Moderator
Check your umbilical cord to the vehicle, and the connections in the junction box on the the trailer. You have a poor/loose connection some where.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
JBarca
Radnor, Ohio, USA
Posted: 03/18/23 07:02am Link  |  Quote  |  Print  |  Notify Moderator
We need a little more info to try and help better. You may have more than one issue going on at a time.
What year is the camper? Make and model?
Not sure if you are the original owner or not; any idea how many towing miles are in it?
What brand and model brake controller do you have?
When you stated you appeared to have corrected the issue, then after some time passed into towing once again, the brakes stopped working. What told you the brakes were not working in "all" the times when they stopped working? Did the brake controller flash, if the brake controller had no errors; you could not feel the brakes working, etc.? We need more info on how you knew they were working and when they were not working.
Here are some big-picture things that "might" be going on. Any and all may be going on at the same time.
The melted breakaway switch, these switches do go bad over time. Water gets in and corrodes the contacts making them fail in a few ways.
- The pin can get frozen in place as the O ring dries up, and it feels like it jams the plunger in.
- When the contacts corrode, and the pin is pulled, the resistance in the switch is very high and starts creating a lot of heat, and, in some cases the switch melts.
- The contact corrosion can sometimes corrode the contacts together if it is bad enough, with the plunger in place. This allows the power to be on a lot of the time and since the connection has high resistance, it creates a lot of heat for a long time and might be what melted your switch.
- The 3 above are the more common failure modes; I'm sure there are more. If you read the directions on these switches, many brands state to replace them every 3 to 5 years. The breakaway is a forgotten safety device. I have seen many campers 10 to 20 years old still with the original switch.
While you changed the switch, the braking problem still seems to be happening. As I stated, you may have more than one problem at the same time. Yes, the breakaway switch was bad, but there can be more.
1. As the other poster stated, check the 7 wire brake plug/connection. Clean up all the contacts. It is common that corroded contacts can make and break as the truck bounces down the road or the cord is pulling from not enough clearance in a turn etc.
2. You may have the classic old camper worn wire inside the axle tube problem. As the camper gets older with higher towing miles, the wire inside the axle tube is chaffed bouncing down the road. The hot wire or ground wire can have the insulation worn clean through to the wire. When the hot wire touches the tube, and you apply the brake power, it shorts the brake coil from getting any power. This comes and goes depending on how the worn wire lands in the tube.
3. You have bad brake connections in the wiring in the camper. It can be the ground wire not making contact. While the hot wire gets looked at a lot, losing ground will stop the brakes from working also. In this case, if you lose the DC -, (ground), in the 7 wire cable where it attaches to the camper, the camper frame lost ground or any other grounding place all the way to the brake coils.
4. If the breakaway switch was partly on for a long time when it failed, the brakes had some level of power going to them for a long time while towing. After you check all the wiring as stated above, you may have to pull the brake drums and look inside for mechanical issues. There are many issues that can happen inside, maybe not all 2 or 4 brakes at once, but if the breakaway was sending power for hours on end while towing, something could be wearing at a higher than normal rate.
You stated, it seemed like when you pulled the new breakaway switch pin and reinserted it, the brakes seemed to start working again. This may just be a coincidence, it is not the cure of your problems. Applying full power and then removing it, cycles the magents and can wiggle the magnet arm. This wiggle action may free up a brake that was partly tight being engaged when you stopped. The event was temporary and random.
Older campers have the above more frequently than newer ones, but not always.
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
deltabravo
Spokane, WA
Posted: 03/18/23 08:18am Link  |  Quote  |  Print  |  Notify Moderator
DITTO.
It's probably a loos umbilical cord at the truck receptacle.
On the trailer cor, take a screwdriver and move the electrical contact to cause more "spring" tension when the cord is plugged in to the truck.
Also check the truck and trailer connector for dirt, grit, grime, corrosion.
And NEVER use one these caps to "protect" the trailer plug. They cause more problems than they solve. This video I made proves it.
Emolsee
Reno
Posted: 03/18/23 09:46am Link  |  Quote  |  Print  |  Notify Moderator
For a bit more information…
My brake contrôler is a Tenonsha Sentinel. Our tow vehicle is a 2003 Ford Excursion and I’m assuming the brake contrôler was purchased and installed early in the life of this vehicle by the original owner.
Our trailer is a 2015 Rockwood Signature Ultralite by Forest River model # 8327SS. My brother bought it new. It has more than 20k towing miles on it.
For this controller… generally when you hook up the trailer cord there is a steady green light that is illuminated letting you know everything is working correctly. If that green light flashes it indicates a direct short or an excessive current request. If brakes are applied when the green light is flashing, the additional lights (meant to indicate firmer trailer breaking) all flash and you feel no trailer braking so you know that the brakes are not working.
On my drive yesterday…
-We hooked up and initially the controller had a stead green light indicating everything was fine.
-Before moving the trailer the contrôler began blinking a single green light noting a short or excessive current request.
- I crawled under the trailer to once again check the grounds and the see if there could be a visible problem, I checked the connections to the batteries, and I took a screw driver and moved all the contacts closer. I plugged in a 7 pin tester and it showed no problems. Green light was still blinking. I pulled the break-away plastic pin and reinserted it and the green light on the contrôler went to steady green.
-As we began driving… Initially the steady green light was on for 30 minutes, then the light flashed indicating a short etc., then the light went steady green again for an hour, then the flashing started and stayed on for more than an hour when I pulled over and unplugged the break-away plastic pin and re-inserted it. this brought the steady green light back on for a while then the controller really did some weird stuff… went completely dark for 30 seconds, came back on with a steady green light, then flashed and did this cycle at random times. Last 30 minutes of the pull yesterday was a flashing green light again indicating no trailer brakes functioning (and it felt this way too).
Could the previous problem with the break-away switch (that I have replaced) have damaged the controller? Should I look at replacing that? Could I maybe have gotten a faulty new break-away switch and think about replacing that? We have towed this trailer from coast to coast with no braking problems until these past few days.
BarneyS
S.E. Lower Michigan
Posted: 03/20/23 07:48am Link  |  Quote  |  Print  |  Notify Moderator
I would try replacing the brake controller. Don't know about the policy now but a few years ago Tekonsha would replace their brake controllers for no cost. All you needed to do was take to a place that sold them and they would give you a new one. Worth a try now I would think.
Barney
Not towing now.
JBarca
Radnor, Ohio, USA
Posted: 03/20/23 09:20am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Your added info has helped.
You are correct, the brake controller was an aftermarket add on by someone. Ford never started adding brake controllers until the 2005 Super Dutys with an integrated controller. The last Excursion, a 2005 model, never got the upgrade, nor did the V10 engine upgrades the Superdutys did.
I agree with Barney, you "might" now have a brake controller issue. At this point, ideally, you can sort out, is the problem in the trailer or the truck?
Here is one way to help sort out truck or camper. You stated this,
That is the setup for the test if you can recreate it or close to it. The truck and camper hitched but not moving, and the brake controller started acting up.
By hitching up and powering the brake controller, but not moving the trailer, the brake controller can warm up, and if the controller starts showing faults, then try this.
Step 1, Unplug the 7 wire cable from the truck. Position the 7 wire cord up so it will not drag the ground.
Now, with the 7 wire disconnected, pull the emergency break away, this will apply full power to the brakes.
Move the truck ahead very slowly. You are trying to do a drag test. You should feel large braking action on the trailer, you do not want to drag the wheels, but should feel very hard braking. Gravel is best for this test so the tires skid, but you can tell real quick if the trailer is braking hard on a hard surface road, 1 or 2 feet movement will tell you, but the camper does have to move about 6" rolling forward to engage the brakes. The wheels may or may not lock up, but you should feel the brakes working.
If the camper has brakes, this does not mean 100% that there is not a trailer problem, but it rules out many things. Enough to at least suspect the issue is in the truck.
When you unplug the 7 wire, and the truck was on, the controller may stop the fault or not. It should sense an unhooked trailer at least. Not sure what it will read out as, as the controller may be damaged. But you at least now know, the trailer brakes worked during the breakaway test.
There is also something you should know, some brake controllers cannot handle a large current back feed from the camper. By pulling the emergency break away, with the 7 wire cord attached to the truck with the brake controller powered up, is a high back feed current into the controller from the camper battery. That back feed action has damaged some brands/models of brake controllers.
If you want to try to reset the brake controller in a test mode, pull out the 7 wire cable and plug it back in, or turn the truck power on an off, but do not use the emergency breakaway switch as that can be a problem.
Here is a thought, when your breakaway switch was failing originally and melted the switch, that event was sending a back feed of current into the truck brake controller. That may have damaged the controller, and now you are fighting a brake controller issue.
There should be nothing wrong with your new breakaway switch unless something really odd going on. It is just a simple switch, on or off, unless it is corroded which is not yet.
Hope this helps, and let us know how it goes.
John
