pbitschura
SE MN
About to pull the trigger, I think, on a used 2020 Braxton 24 RB with some hail damage on passenger side sidewall. Will this affect insurability and should I have it noted for warranty purposes?
2020 Braxton Creek 24fb travel trailer
MNtundraRet
Bloomington, MN
I would be worried about possible damage to roof and seams. Future warranty on current hail damaged sidewall (or else ware) is suspect. You purchase is likely listed as: "As is".
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
fj12ryder
Platte City, MO
I have to agree. If there is hail damage on the sides, I'd be checking the roof very carefully.
Howard and Peggy
"Don't Panic"
StirCrazy
Kamloops, BC, Canada
pbitschura wrote: About to pull the trigger, I think, on a used 2020 Braxton 24 RB with some hail damage on passenger side sidewall. Will this affect insurability and should I have it noted for warranty purposes?
I'm assuming it's aluminum siding. as long as there are no tears where the the dints are it will just be cosmetic. like others have said check the roof and roof to wall seams to make sure they haven't been pulled out by a dint and are still sealed up good. any other damage on that wall would likely be declined by insurance as it was previously damaged but other than that its just if you are willing to put up with the dints. could use it to try get more off the price... tell them you want the side wall fixed for the same price your at now, or drop a few K off the prie and see if they go for it.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
midnightsadie
ohio
your not saving enough money to look at the drnts evry time your out side. and it,ll be a real pain to sell down the road. but you,ll be the talk of the camp ground. walk away from this.
MitchF150
Puyallup, WA
It might be more aerodynamic with those dimples on it! Think of why a golf ball has all those dimples on them. It's so they fly farther. I think "Myth Busters" did a thing on it way back when?
Mitch
goducks10
There
Walk away. There's too many used RV's out there for sale and prices are dropping. Why settle for a possible fixer upper?
If the price is right…IE, less than other used campers that have at least the same size and amenities.
pbitschura
SE MN
I've determined there is only light cosmetic damage on the passenger sidewall. The roof will be resealed and inspected by me at the pdi. I will get a new battery, full 2 propane tanks, and I got the 400.00 prep fee waved. I'm satisfied with the deal and pulled the trigger. Thanks all for your input.
MNtundraRet
Bloomington, MN
Thank you for letting us know what you decided to do.
