RV.Net Open Roads Forum: Fifth-Wheels: Creak when reversing the fifth wheel
 > Creak when reversing the fifth wheel
Page of 6
tourusa
Ft Lauderdale
Posted: 03/18/23 06:49am Link  |  Quote  |  Print  |  Notify Moderator
Hi all I have a B&W fifth wheel hitch and dexter axle on the fifth wheel, when reversing I’m now getting a creak followed by a bang when stopping,
Any ideas is it the B&W which need grease or the axle in the fifth wheel
Sounds like an old bed
Can you suggest or confirm If I can use litium grease from Walmart in the jaws of the fifth wheel and anywhere on the fifth wheel thanks
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
fj12ryder
Platte City, MO
Posted: 03/18/23 07:36am Link  |  Quote  |  Print  |  Notify Moderator
I prefer Red and Tacky for grease. There is a grease zerk on the underside of the hitch head, and the rubber supports for the head should have some grease put on them. Also a little grease on the inside of the jaws where they contact the pin is a good idea. Is it a slider hitch? Have you checked the tightness of all the bolts?
However, I think your problem lies with the trailer. You don't say what it is, what size it is, or how old it is, but I would be checking the suspension if I were you.
Howard and Peggy
"Don't Panic"
TXiceman
Bryan, TX
Posted: 03/18/23 07:37am Link  |  Quote  |  Print  |  Notify Moderator
The first thing to do is to check all bolts and nuts on the hitch, the hitch attachment to the truck frame and the pin box on the trailer. These are connections that should be checked annually.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Cummins12V98
on the road
Posted: 03/18/23 08:17am Link  |  Quote  |  Print  |  Notify Moderator
White lithium goes on top of the rubber mounts that support the pivot head. Regular grease gun suspension/bearing type grease is for the jaw surface that contacts the king pin. It is also used on the ONE and ONLY grease zerk on the bottom side of the pivoting head. Thats it!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Likes to tow
Huntington WV
Posted: 03/18/23 08:26am Link  |  Quote  |  Print  |  Notify Moderator
You need someone to stand beside your rig and try moving back and forth to see if you can duplicate the sound. You can't solve it from the cab of the truck. Had problems like this before with my old hitch. It was the mounting bolts in the hitch to the frame of the truck. My new Ford has the puck system and a B&W hitch. There is no noise from the B&W
enblethen
Moses Lake, WA
Posted: 03/18/23 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Can you tell where noise is at, trailer or hitch?
I would start by checking springs, spring shackles, shackle straps, and spring perches.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
tourusa
Ft Lauderdale
Posted: 03/18/23 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Hi I think the noise is at the axle, the 5 wheel is a 2020 40ft vanleigh twin axle just hit lots of rain yesterday. I was underneath a week ago and all is secure, leaf springs look good
For the trailer - Are the grease points on the axle accessible without removing the wheels
For the fifth wheel hitch, I have the factory mounts in the f350. Can I get red tack from Walmart and can I use in both axle and fifth wheel hitch in the truck.
* This post was edited 03/18/23 09:13am by tourusa *
tourusa
Ft Lauderdale
Posted: 03/18/23 09:20am Link  |  Quote  |  Print  |  Notify Moderator
ITEM # BWRVK3305 - hitch details
fj12ryder
Platte City, MO
Posted: 03/18/23 09:47am Link  |  Quote  |  Print  |  Notify Moderator
If you have greaseable wet bolts, then they should be accessible without pulling the wheels. Some builders put them on the inside, so you might not see them right off. While Red and Tacky is wonderful for the zerks, B&W does recommend lithium grease for the saddle mount, as Cummins recommended above.
Creaking while backing/turning isn't too concerning, it's the bang that I would try the hardest to locate.
tourusa
Ft Lauderdale
Posted: 03/18/23 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Page of 6
