RV.Net Open Roads Forum: Fifth-Wheels: Creak when reversing the fifth wheel
 > Creak when reversing the fifth wheel
enblethen
Moses Lake, WA
Posted: 03/18/23 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have standard looking leaf springs on trailer?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
tourusa
Ft Lauderdale
Posted: 03/18/23 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Hi yes standard leaf
Currently coast to coast
F350 dually 2020
2020 Vanleigh Pinecrest 392MBP
B&W Companion OEM 5th Wheel Hitch for Ford Super Duty Prep Package - Dual Jaw - 25,000 lbs
ITEM # BWRVK3305
enblethen
Moses Lake, WA
Posted: 03/18/23 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Many of the small components wear. You can see on this site etrailer/dexter many of the components
fj12ryder
Platte City, MO
Posted: 03/18/23 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Probably 7,000 lb. axles I'm thinking. The GVWR is around 15,000 lbs. I think.
Howard and Peggy
"Don't Panic"
tourusa
Ft Lauderdale
Posted: 03/18/23 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Your correct with the weight looking at the parts from etrailer how often do they need switching out
enblethen
Moses Lake, WA
Posted: 03/18/23 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
The plates on the shackles may last around 10,000 miles. There are two thicknesses with same bolt pattern. Thicker ones will last longer. As shown on etrailer there are ones that have lube points.
The axles should be stamped for part numbers and weight. Normally on shoulder end of axles.
