RV.Net Open Roads Forum: Propane Powered Engines Featuring a 7.3 Ford and 6.7 Cummins
Search only in Tow Vehicles
 > Propane Powered Engines Featuring a 7.3 Ford and 6.7 Cummins
agesilaus
North Florida
Posted: 03/20/23 07:23am Link  |  Quote  |  Print  |  Notify Moderator
I bet the valves will love it
I doubt it, diesel engine valves get lubrication from the fuel. That is an issue with low sulfur fuel, it provides reduced lube.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
JRscooby
Indepmo
Posted: 03/20/23 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Back in mid 70s friend had most of his inherited farm leased out, but kept old WD 45 around for chores. Had converted it and a old VW bug to run on propane. I talked to him when noticed he was driving the car on days he would normally ride his 750 Honda. He just fueled car and tractor from tank installed to heat the house, was less fun, but cost less to drive the car
ktmrfs
Portland, Oregon
Posted: 03/20/23 09:20am Link  |  Quote  |  Print  |  Notify Moderator
in a diesel fuel is injected into the cylinder after the valves are closed, not sure how it provides any lubrication.
2011 Keystone Outback 295RE
ktmrfs
Portland, Oregon
Posted: 03/20/23 09:22am Link  |  Quote  |  Print  |  Notify Moderator
a spark ignition engine designed for propane operation is capable of high power output and efficiency, since propane like alcohol has a higher octane rating one can run much higher compression and much more spark advance.
Course it will use more gallons of fuel than gasoline due to the lower energy content, but it gains in thermal efficiency to partially offset.
Dual fuel engines another story, spark advance can be adjusted but not easy to adjust compression ratio.
agesilaus
North Florida
Posted: 03/20/23 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Let me say I'm no automotive engineer, I was going on posts like this:
ack of lubrication is a universal problem in the diesel world - older vehicles weren’t built to run on ultra low sulfur diesel (ULSD) and new vehicles are built with extremely tight tolerances, producing higher pressure and temperature, making the lack of lubricity possibility catastrophic. Every single diesel engine injection system relies on diesel fuel as a lubricant to protect and lubricate all the moving parts within the fuel system including injectors, in-line pumps and injection pumps. If the lubrication of the fuel isn’t good enough, the internal components begin to wear against themselves and can fail from excessive wear.
post
Latner
Indiana
Posted: 03/20/23 09:51am Link  |  Quote  |  Print  |  Notify Moderator
agesilaus wrote:
Yes... But I think I would rather have this than a EV truck that maybe able to pull your camper ~100 miles at best. Plus these guys claim they're able to maintain factory power.
Dream on if you think the ----- types will let you have one of these. They are busy attacking gas stoves right now after all.
and washing machines
ktmrfs
Portland, Oregon
Posted: 03/20/23 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
post
yes, before ULSD the fuel pumps relied on the sulphur for some lubrication. it was for the high pressure fuel pump, and injectors, not the valves.
However any diesel sold afer about 2005 is designed for ULSD
FishOnOne
The Great State of Texas
Posted: 03/20/23 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Don't forget the 6.7 cummins that was featured in the video is a propane only engine. This thing has spark plugs.
* This post was edited 03/20/23 03:32pm by FishOnOne *
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
Learjet
Louisiana
Posted: 03/20/23 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
"Cummins’ biggest embrace yet of a growing menu of low carbon fuels will be applied across their B Series, L Series and X Series engine lineup. Fuel choices will include diesel, natural gas, hydrogen, propane or gasoline. Once spec’d, engines will run on one fuel only.
The first engine expected to roll out in 2024 will be a 6.7-liter gasoline-ready option, which Cummins sees as a good fit for pickups and other vehicles needing “diesel-like durability and performance,” according to Cummins’ president of engine business Srikanth Padmanabhan"
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2022 Jayco Pinnacle 32RLTS, Onan 5500, Disc Brakes, 17.5" tires
B&W Ram Companion
theoldwizard1
SE MI
Posted: 03/20/23 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
I worked in that industry for awhile, so I have some experience.
Propane's biggest issue is the space required for the tank the seasonal price. If you have a fleet and have the space for your own refill station and have a HUGE tank, you can negotiate a good price during the off season.
Retail fills will kill you during the heating season !
