SCADAMAN29325
Clinton, SC
We were shown how to use the awning several times, but now one arm is not releasing to be able to roll out.
I've also watched a few videos and had a couple of seasoned campers stop by that saw my struggle.
I unscrewed the knob a few turns on each arm, released the side latches and released the top latch. When I pull the lanyard, the right side (with the top latch) will pull out about 6 inches, but the other arm is stuck and puts it in a bind.
The right arm with the top latch is free to move, but the other arm is stuck in the latched position. Climbed on top grabbed the stuck arm and pulled/yanked/pushed and it will not budge.
It's a Carefree, one of the passers-by has the same awning and showed me how his works and tried mine, but it didn't work for him either.
I now have it latched and stowed for travel, but perturbed I can't use our awning.
Any help out there for my awning situation is much appreciated!
Thanks!
THANKS! Phil and LuAnn
1st timers, brought it home 2022-10-19.
1994 Fleetwood Jamboree Rallye
M-T31-Ford-460, 1994 Ford E350
I may not know what I am doing, but I am having fun doing it!
opnspaces
San Diego Ca
Mine sometimes gets jammed at the top. to fix it I have to push it to one side or the other (like front to back not in and out) and it eventually releases.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
wildtoad
Blythewood, SC
Sounds like awning arms may not be square causing the one side to jam when closed. Might try LIGHTLY tapping each side at the top with a hammer.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
BarneyS
S.E. Lower Michigan
Try pushing up and out at the same time. Might have to push up quite hard.
Barney
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
Dutch_12078
Winters south, summers north
If lifting up a bit on the handle on the stuck arm releases it, make sure the stop at the bottom of the arm is not damaged. I've replaced a number of damaged stops for folks that let the arm drop slightly and jam. I use nylon bushings from any good hardware store to replace them. If the old nut and bolt are badly rusted, replace them too.
Dutch
2001 GBM Landau 34' Class A
Is this a manual awning? On both the "House" and Roller ends somewhere there is supposed to be a screw that keeps the fabric from sliding front to rear (or side to side depending on how you look) good chance it's not there and the fabric has "Shifted" right or left a bit.. you may need to unlatch then on the ladder get a bit..er.. violent with a pry tool to start the arm loose (Caution damage can easily result) once its' out Inspect you may need to shift the fabric a bit (Lift the roller and work it like quarter inch) then see if it lines up better.
There are also other things that can shift a bit if not properly pinned and cause mis-alignment.
Recommendation is a professional if you are not comfortable I know a good one in the Flint. MI area (Assuming she's home from her Florida office where she winters) yes she is a she. She's good though.. I know a decent dealer/service center too also near Flint.
BarneyS
S.E. Lower Michigan
wa8yxm wrote: Snip...
What good is a professional service tech or dealer in Flint, MI when the OP is located in Clinton, South Carolina? ![scratchead [emoticon]](http://www.rv.net/sharedcontent/cfb/images/scratchead.gif)
Barney
SCADAMAN29325
Clinton, SC
Thanks all. I'll wait till I return home to mess with it. I don't want to create an emergency out on the road.
BTW, yes, it's manual. From the info above I do feel like I can resolve the issue once I'm home. It's not a big deal here in Myrtle Beach State Park, there's lots of shade and no rain.
Thanks again!
Phil
Z-Peller
Oceanside BC
Start by opening clips on arms, then loosening knobs on arms, then release the roller with your rod, then pull lanyard out a few inches so roller unwinds slightly which will release tension, then give a good yank up on the lever on the bottom of each arm and the arm will come out of the designed notch at the top, and awning is now ready to pull rest of the way out……when putting awning away, let the last few inches go, so the arms slam hard and drop into the notch at the top, then you know the arms are locked in place.
Many awnings come open on the road because people don’t know those arms have a locking notch at the top and think it is just the roller tension holding it from deploying….Once you get your routine you will find it quite simple to do.
Bill..
2017 Bigfoot 10.4 camper...2016 GMC 3500 4x4 Xcab Duramax Dually...
Martyn
Panama City Beach, FL USA
I had a similar problem with my last trailer. In order to release the offending arm I would detach it at the bottom and lift it up a bit. That released the top and I then reattached the bottom and all was well. Did that every trip for about 11 years!
2020 Keystone Cougar Half-Ton 27SGS;
2019 Dodge Ram 2500 QC 4x4 6.4 Hemi BigHorn;
DEMCO Autoslide; 2 Honda EU2000i's;
Our Website
