RV.Net Open Roads Forum: Travel Trailers: Stop Light/turn signal blowing bulb
 > Stop Light/turn signal blowing bulb
supercub
Modesto CA
Posted: 03/20/23 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
I keep blowing bulbs on the left side of my travel trailer. Fuse remains intact. Any idea why the bulb would blow and not the fuse? What should I check?
Thanks
ssthrd
Vancouver Island
Posted: 03/20/23 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Check the light socket for corrosion. Maybe the bulb is OK......
I little vinegar on a q-tip does a great job cleaning contacts.
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
WayneAt63044
St. Louis, MO
Posted: 03/20/23 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Wrong bulb number? Same bulb as the right side?
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
JRscooby
Indepmo
Posted: 03/21/23 04:29am Link  |  Quote  |  Print  |  Notify Moderator
Bad or marginal ground can cause this issue.
Or even lose fit in socket.
Back when I ran incandescent bulbs in truck taillights I would put a half pea sized dab of silicone on the glass near base. Old hands said it helped, absorbed vibration before it got to filament. Seamed to help.
bucky
Raleigh metro
Posted: 03/21/23 04:58am Link  |  Quote  |  Print  |  Notify Moderator
By blow do you mean one or both of the filaments are broken or are they intact but just not working?
Puma 30RKSS
StirCrazy
Kamloops, BC, Canada
Posted: 03/21/23 06:34am Link  |  Quote  |  Print  |  Notify Moderator
how long do the bulbs last? and are you buying the cheapest one or decent one
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
