RV.Net Open Roads Forum: Tech Issues: How long should a battery last?
 > How long should a battery last?
Page of 8
swimmer_spe
Sudbury, Ontario, Canada
Posted: 03/22/23 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
Typical code 24 battery, how long should it last with lights and electric RV fridge? I am only getting about 24 hours before it gets under 11.5V. Also, would a battery shop have a way to properly test the battery to see if it is actually any good? Would an RV shop be able to properly test it?
MNtundraRet
Bloomington, MN
Posted: 03/22/23 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
That's about right. You should not be running an electric fridge on that battery. The battery will be shot before the end of the year.
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
swimmer_spe
Posted: 03/22/23 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
We have no choice as it is a 12v/120v fridge. I typically do not use it on 12v except for while driving.
Posted: 03/22/23 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
A group 24 is around 70-75 amp hours and you can only use about `15 of them before it is run down. So not long
A pair of GC-2 (6 volt golf car in series) are 220 give or take a bit amp hours and you can use half. that's a lot more than one G-24
MNtundraRet
Bloomington, MN
You should use an electric site when camping. If you keep running the battery down you will have nothing working in your trailer.
swimmer_spe
Posted: 03/22/23 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
That is my goal, an electric site. However, it would be nice to boon dock for a weekend without another battery or generator, or wall of solar panels.
swimmer_spe
Posted: 03/22/23 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Brand new trailer with a new battery. I'd rather not need to change the battery out for a weekend of boondocking for a weekend every now and then. If I were doing it once a month or more, then, I would see the need.
MNtundraRet
Bloomington, MN
Posted: 03/22/23 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
You may need to get a generator for boondocking.
ewarnerusa
Helena, Montana
Posted: 03/22/23 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
If boondocking you'll have to run it on 12V, right? Is that how you're testing it during your 24hr test?
With a propane absorption fridge, a single group 24 would probably be be pretty low after a weekend of fridge and lights (also water pump and maybe fans). A 12V electric fridge would be a much larger load on the battery.
Aspen Trail 2710BH | 470 watts of solar | 2x 6V GC batteries | 100% LED lighting | 1500W PSW inverter | MicroAir on air con | Yamaha 2400 gen
wildtoad
Blythewood, SC
Posted: 03/22/23 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Does the fridge have a propane option? If so you should use gas when boon docking. Will use very little battery to operate.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Page of 8
