RV.Net Open Roads Forum: Truck Campers: Happijac issue
 > Happijac issue
mattyj
Long Island.New York
Posted: 03/23/23 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
I’m trying to get the remote for these to work with the receiver , but No! I can get all the jacks work at once and the rear to work ok , but the fronts don’t work, I have tried connecting cable to the receiver from the remote, and to reprogram the remote, but they still don’t work, right. It’s also very difficult to find someone who will service these Jacks . Can anybody give me some help?? Thanks
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs ,Stable Loads ,rear Helwig Swaybar,airlifts 5000 , Method 305 HD rims . 2019 Adventurer 89 RBS, slideout, Generator
jimh406
Western MT
Posted: 03/23/23 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
Have you tried changing the battery or moving closer to the fronts or sending unit? Have you tried manually cranking the fronts to make sure they aren't corroded?
Other than that, I had one Atwood remote die on me at about 1 year. The second one is still going strong 15 years later. You might have to buy a new remote.
Good luck.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
mattyj
Posted: 03/23/23 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
Good luck.
I manually cranked one of the Fronts,I will try the other and I have changed my position to be closer to the receiver, no difference, and I changed the batteries, still no good . Happijac gave me a price of $300 for a new remote. I found one on eBay for 100 but it said new/other, I didn’t like the fact that it said “other”but I bought it and i was sent the wrong remote, the model number was wrong . So when I get my refund I’m gonna try it again for the right one.
B-n-B
Colorado
Posted: 03/23/23 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure the lever on side of the jack is in the UP position. Easy to overlook.
https://www.happijac.com/images/pdfs/10keywired.pdf
2019 Chevy 3500HD LTZ DRW
2021 Lance 975
mattyj
Posted: 03/23/23 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
yes, they are all in the up position do
mkirsch
Rochester, NY
Posted: 03/24/23 07:31am Link  |  Quote  |  Print  |  Notify Moderator
People are ignoring that ALL THE JACKS WILL WORK AT ONCE.
That means the jacks are getting power. That means the jacks are NOT stuck. That means the jacks are getting a signal. That means the lever on the side of the jacks are in the correct position.
The problem is either in the remote, or in the jack controller in the camper. The problem is electronic, and for most of us the only thing we can do is replace things until it starts working again.
It would be interesting if you could swap the wires from the front jacks to the rear jacks, and verify that the problem follows the wiring, not the jacks.
mattyj
Posted: 03/24/23 07:49am Link  |  Quote  |  Print  |  Notify Moderator
I will go look to see if I can swap the wires from the front jacks to the rear jacks. I’m not sure if they will reach.
StirCrazy
Kamloops, BC, Canada
Posted: 03/24/23 08:10am Link  |  Quote  |  Print  |  Notify Moderator
swap them at the control board. just plug the fronts into the bak sockets and the other way for the backs
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
SoonDockin
Oklahoma
Posted: 03/24/23 08:31am Link  |  Quote  |  Print  |  Notify Moderator
My camper came with two remotes. One wired and the other wireless. Is it possible you have a second remote?
2022 Ram Laramie 5500 60" CA New pic soon
2018 Arctic Fox 1140 Dry Bath
Sold 2019 Ford F450 King Ranch (was a very nice truck)
mattyj
Posted: 03/24/23 11:00am Link  |  Quote  |  Print  |  Notify Moderator
I swapped all the wires on the control board, and it made the jacks behave worse than before so I just put them back to the original position
 > Happijac issue
