RV.Net Open Roads Forum: Truck Campers: Happijac issue
 > Happijac issue
mattyj
Long Island.New York
Posted: 03/29/23 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
stevenal wrote:
1 Up and down refer to the camper direction. It's easy to get this confused, since the jacks extend downward to move the camper up.
2 If the jacks move opposite to what's described above, you have a polarity issue.
3 When all else fails, I find a power cycle reboot will cure things.
. I tried all those things, nothing changed. Thank you for your response!
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs ,Stable Loads ,rear Helwig Swaybar,airlifts 5000 , Method 305 HD rims . 2019 Adventurer 89 RBS, slideout, Generator
Ski Pro 3
Placerville area
Posted: 04/08/23 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
Open the remote. There's a ribbon cable that connects the keypad to the circuit board. It's held to the circuit board with a zero insertion force tab. Remove the tab. Remove the ribbon. Clean the ribbon connections with a pencil eraser. Reassemble.
Mine has done this a couple times. Now works fine.
mattyj
Posted: 04/09/23 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
. Thanks but I have determined it’s one of the jack motorheads is dead , and Happijac has discontinued making them until the end of June . I guess I’ll wait.
srschang
Western NY
Posted: 05/12/23 07:06am Link  |  Quote  |  Print  |  Notify Moderator
So, my 3 year old Northstar 12STC has Happijac 4800 jacks on the front, and Happijac 4160 jacks on the rear. The motor on one of the front jacks has died. After discussion with folks at Etrailer, the new style Happijac motors won't work with my current jacks. They said the only thing I cand do is replace all 4 jacks, the control unit, and remote with the new drive system. $3500 because one powerhead died. Do I have any other options? Thanks.
Not real happy with Happijac at this point.
2022 Ram 3500 Dually Crewcab Longbed Cummins, 2019 Northstar 12 STC
joerg68
St. Ingbert, Germany
Posted: 05/12/23 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Revert to manual crank mode? Get a decent battery drill and the required drill bit...
We had HJ electric jacks on our previous camper, and their reliability was not very impressive then. We did not order them for our 2017 Northstar. We now use a good high-torque Makita 18V drill. Then again, we take the camper off only very rarely, so it is not that much of an inconvenience.
You may be able to find some used motors on the web. If you have some time.
mattyj
Posted: 05/12/23 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Since Happijac does not manufacture the 4200 model that I have , and the Motörhead replacement won’t be available til the end of June, I bought the Motörhead to an electric motor repair shop and hoping for the best !
skidsteerpilot
North Carolina
Posted: 05/17/23 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry to hear about your troubles. We've had success with having the motors cleaned/refurbed at a repair shop so hopefully you will too.
Could you elaborate on "won't be available until the end of June" ? Will they be offering the motor/head units again? Will this be Lippert?
The Grey Goose
2017 Ford 350 DRW Flatbed / 2012 Northern-Lite 10-2
https://thegreygoose.net
srschang
Western NY
Posted: 05/18/23 08:59am Link  |  Quote  |  Print  |  Notify Moderator
One of my three year old Happijac motors (old style) has died. Right now, replacements are not available. Here's what I got from Lippert this morning:
Good afternoon,
The motors will be available again at the end of June, the PN is 2022003046, and they are $220.95 each.
If you would like to order one, you can do that at any time via email or over the phone, but it will not ship until the end of June when these are back in stock.
To order via email, please reply with quantity, phone number, and a good shipping address. We will create the order and email you a secure link for payment.
Thank you,
Ashley W
Lippert Care Center Leveling/Slides Parts Agent
p: 432.LIPPERT | f: 574.534.7161
Lippert
mattyj
Posted: 05/20/23 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Good afternoon,
Thank you,
Ashley W
Lippert
. With the same issue, I picked up my HappiJac 4200 Motörhead from electric motor repair shop and for 150.00 problem solved all for 150.00! Now all the jacks are working!
user113
Lebanon, KY
Posted: 05/24/23 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
The most amazing thing in this statement is that you were able to find an "electric motor repair shop" in this day and age!! Glad you were successful.
 > Happijac issue
