mattyj
Long Island.New York
user113 wrote: mattyj wrote: With the same issue, I picked up my HappiJac 4200 Motörhead from electric motor repair shop and for 150.00 problem solved all for 150.00! Now all the jacks are working!
The most amazing thing in this statement is that you were able to find an "electric motor repair shop" in this day and age!! Glad you were successful. . Thanks , the shop mainly rebuilds starters and alternators , and camper jacks.
2006 Ford F 350, 6.0 PSD 8 Foot Bed 4x4 with Torklift Tie downs ,Stable Loads ,rear Helwig Swaybar,airlifts 5000 , Method 305 HD rims . 2019 Adventurer 89 RBS, slideout, Generator
srschang
Western NY
A follow up to my Happijac old style motor dying on my 4800 jack. I ordered a new style motor, and installed it on the 4800 jack. Works fine, very quiet. Not sure if the new clutchless style motor is turned off by the new style controller, or in the motor itself. If it shuts off in the motor, I should be OK. If it's shutoff by the controller, I'm still using my old style controller, so I'll have to be careful when I retract the jack all the way in so the fuse in the controller doesn't blow.
2022 Ram 3500 Dually Crewcab Longbed Cummins, 2019 Northstar 12 STC
egarant
Mission Viejo CA
I had a similar problem, it was the remote. The red and blue arrows get used a lot and eventually die. Buy a new one for $150 on Amazon, I now carry two at all times.
2021 FORD F350 dually 4x4 with 4.30 gears
2013 Eagle Cap 950
480 Watts Solar, 3K VictronConnect Multiplus II, VictronConnect smart DC-DC charger, VictronConnect 100/30 solar controller, 250 amps of lithium batteries by LifeBlue
