RV.Net Open Roads Forum: Camp Cooks and Connoisseurs: The Bacon Thread
Search only in Camp Cooks and Connoisseurs
Open Roads Forum  >  Camp Cooks and Connoisseurs
 > The Bacon Thread
magnusfide
On the Road Again and Again and Again...
Posted: 03/24/23 07:41am Link  |  Quote  |  Print  |  Notify Moderator
A thread for all things BACON:
Hacks
Recipes
Smoking vs non-smoking.
"The only time you should fear cast iron is if your wife is fixin' to hit you with it."-Kent Rollins
First law of science: don't spit into the wind.
Magnus
magnusfide
Posted: 03/24/23 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Came across this article about how to make a crispier bacon. I never heard of it and I have Southern relatives. Have you heard of this?
Tip for crispier bacon
pianotuna
Regina, SK, Canada
Posted: 03/24/23 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I love cooking my bacon in the microwave. Now if I could do a non scrambled egg I'd be in microheaven.
Regards, Don
Pangaea Ron
Anacortes, WA, USA
Posted: 03/24/23 09:39am Link  |  Quote  |  Print  |  Notify Moderator
I use my George Forman grill, it keeps the strips flat, and the grease drains off.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
Latner
Indiana
Posted: 03/24/23 10:52am Link  |  Quote  |  Print  |  Notify Moderator
Cook mine on foil on the grill.
theoldwizard1
SE MI
Posted: 03/24/23 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
One of the simplest things you can do to make bacon easier to fry is use kitchen shears and cut the strips in half !
You can cook bacon in a microwave WITHOUT making too much of a mess. Start with a large, dished plate. A glass pie pan s even better. Lay down a double layer of paper towel. Add your bacon but do not overload! Add another double layer of paper towel.
Cook for about 2 minutes. This time depends on the power of your microwave and the amount of bacon you are cooking.
Now the messy part. Move partially cooked bacon to another plate with a double layer of paper towel. Place a double layer on top. It should take less than 2 minutes to finish cooking. Adjust time for chewy or crispy.
The bacon grease soaked paper towels WILL ATTRACT CRITTERS ! Dispose f accordingly.
pbeverly
South Carolina
Posted: 03/25/23 04:24am Link  |  Quote  |  Print  |  Notify Moderator
Bacon on Blackstone followed by scrambled eggs and hash browns.
Ridgeway, SC
hondapro
Central Pa
Posted: 03/25/23 05:05am Link  |  Quote  |  Print  |  Notify Moderator
That is how I do it. It is the best.
Steve
2016 F-350 6.7 Diesel
2022 Keystone Sprinter 32BH
B&W Companion
eHoefler
ozark mountains
Posted: 03/25/23 06:07am Link  |  Quote  |  Print  |  Notify Moderator
Bacon in the smoker dripping all of its goodness on tri trips, chicken, turkey, lobster, shrimp, fish, hashbrown casserole, mmmmm good
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
ICamel
Oregon
Posted: 03/25/23 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
Bacon - Oven Cooked
Line a baking sheet with foil. This will make cleanup easier later.
Arrange the bacon slices on the foil and place the baking sheet on the center rack of a COLD oven. (Try not to stretch the slices out. Just gently drape the bacon across the pan.) Close the oven door. Turn the oven on to 400°F. Walk away.
Come back 17 to 20 minutes later(less if thin slices). As soon as the bacon is golden brown, but not excessively crisp, it's done. The exact time will depend on the thickness of the bacon slices, and also on how quickly your oven reaches the target temperature.
Remove the pan from the oven. Transfer the bacon to paper towels to absorb any excess fat.
REMEMBER: Don't pre-heat the oven! Make sure the oven is cold when you put the bacon in.
Keep your eye on the bacon during the final few minutes of cooking to make sure that it doesn't burn.
I probably found this recipe here?
* This post was edited 03/25/23 04:54pm by ICamel *
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
 > The Bacon Thread
