RV.Net Open Roads Forum: Tow Vehicles: Chaning Differental oil ???
Search only in Tow Vehicles
 > Chaning Differental oil ???
ilvtravln
Calif.
Posted: 03/26/23 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Have an 03 F350, 90K miles, how often should the diff. oil be changed ? Ford lists the oil that came with is as synthetic. We do about 1/3 towing and the rest around town. Thanks
Art
Posted: 03/26/23 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
How often? Now. If it’s 20 year old oil. That said once I do an early diff change on a new or new to me vehicle, I go at least 50k between changes with good synthetic gear lube.
PS, if it’s an early 03 7.3 you have a very desirable vehicle if it’s been kept up and basically used only rarely.
MitchF150
Puyallup, WA
Posted: 03/26/23 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
20 year old gear oil... I'd change it.
KD4UPL
Swoope, VA
Posted: 03/26/23 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Read the manual for sure. It's probably either 50,000 miles or 100,000 miles depending on use. Towing and running around town are both hard on it. Long highway trips not towing would be easy life on the oil.
I'd change it.
wildtoad
Blythewood, SC
Posted: 03/26/23 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
This…..
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
agesilaus
North Florida
Posted: 03/26/23 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
I did it on our 2012 F350 4WD including the transfer case and it was easier than I expected. I used the OEM Ford fluid. I also got a pump to pump the old stuff out and the new stuff in. Or did I use a drain plug? It's been awhile, definitively used a pump to add it back tho.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
BarabooBob
Baraboo, WI
Posted: 03/26/23 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
On my F150, the transfer case was super simple. Pull the drain plug, let it drain, and refill. The rear differential requires removing the rear half to drain, reinstall and refill. For the front differential, I used a pump and removed as much of the fluid as possible and refilled it. Total job took me about 2 hours.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
RAS43
Littleton,CO
Posted: 03/26/23 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, do it now along with transfer case and front diff. I have an '06 and change mine about every 5 years. But I live at the foot of the Rockies and tow a bunch in them. Towing is hard on gear boxes.
dodge guy
Bartlett IL
Posted: 03/27/23 04:51am Link  |  Quote  |  Print  |  Notify Moderator
When I had my TT I changed the diff fluid every 25k miles. It was easy for me to do and sometimes I had access to the fluid. I also did my trans fluid as often. Same for brake fluid.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JRscooby
Indepmo
Pump to remove the fluid? Much of what you want to get out will be in the oil that stays in the bottom, because heavy. Draining thru hole, better chance will come out. Drain, add little solvent, (below level of bearings), drain again, better still. Removing pan or cover to wash out is best when practical.
While a pump is easiest way to refill, the cost and storage of a tool you will likely use once every few years. (Book tells you miles. How many years to run miles? Now if you trade trucks at 175% of that miles, you go a long time before use again. How much oil does diff hold?
Now it is hard and messy to pour thru the little hole, with no room for funnel, but a suction gun, that works like a syringe, is cheap, can get the job done, EZ to clean before and after use.
