RV.Net Open Roads Forum: Tow Vehicles: Chaning Differental oil ???
Search only in Tow Vehicles
 > Chaning Differental oil ???
ilvtravln
Calif.
Posted: 03/27/23 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
How often? Now. If it’s 20 year old oil. That said once I do an early diff change on a new or new to me vehicle, I go at least 50k between changes with good synthetic gear lube.
PS, if it’s an early 03 7.3 you have a very desirable vehicle if it’s been kept up and basically used only rarely.
Its a 7.3, well kept.
Art
larry barnhart
wenatchee. wa usa
Posted: 03/28/23 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Our 05 chev dually with 116000 miles has had the rear diff changed 13 times. so easy to do I decided to overkill as I do on every fluid for this truck. chevman retired from Rving
chevman
2019 rockwood 34 ft fifth wheel sold
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Posted: 03/29/23 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Lol, I’d love to have the $1000 worth of used oil outta that truck.
FishOnOne
The Great State of Texas
Posted: 03/29/23 10:01am Link  |  Quote  |  Print  |  Notify Moderator
I have a '12 Super Duty with the same rear end with ~260k miles. The rear diff fluid has been changed once to date and is dry as a bone so no leaks. Probably need to do it again.
In your case probably every 100k miles is good if there's no leaks.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs "270k Miles"
'16 Sprinter 319MKS "Wide Body"
larry barnhart
wenatchee. wa usa
Posted: 03/29/23 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
Probably closer to $700.00. no labor spent a lot more on the overkill fluid changes but with 116K mores it does run awesome. Looks great sitting in our garage. chevman retired from rving. "Don't frown because it is over but smile because it happened"
mosseater
Dillsburg, PA
Posted: 03/29/23 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
2007 F-150 sig pic had about 170K miles, daily driver and towing. I changed it because the diff cover was showing signs of rusting through. Fluid was dirty of course, but no obvious shiny chunks. Gears looked like brand new.
Sunset Creek 298 BH
1320Fastback
Vista, Ca
Posted: 03/29/23 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
As a person who just dropped $2,440 on a rear end rebuild I'd do it now. My oil was last changed by myself around 5 years ago and now wish I'd done it more regularly. Oil is cheap comparably.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
wnjj
Cornelius, Oregon
Posted: 03/29/23 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
While that's true, it's also no guarantee that your rear end wouldn't have failed even with fresher oil.
JRscooby
Indepmo
Posted: 03/30/23 04:39am Link  |  Quote  |  Print  |  Notify Moderator
Can't see the differential, so can't say for sure. But what I can say is that in my trucks, changing the diff oil at recommended time made temps run lower. (Transmission made more change).
fj12ryder
Platte City, MO
Posted: 03/30/23 07:02am Link  |  Quote  |  Print  |  Notify Moderator
Well, if it was the oil, it would be about the first time I've heard of not-that-old-oil causing a differential failure. More likely not the oil that caused the failure.
Howard and Peggy
"Don't Panic"
