RV.Net Open Roads Forum: Technology Corner: Windows 11 Experts?
 > Windows 11 Experts?
DD716TED
Washington State
Posted: 03/26/23 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
I have a new Dell desktop..loaded with Win 11 (ugh!) I have a external 1 TB multi partitioned hard drive connected using USB.. The new computer came with a 256 GB SSD (C[emoticon] installed.. (mistake on my part).. I then installed internally another 500 GB HD in the slot provided in the new computer, formatted it and all is well and designated this drive letter H: .. When using file explorer, drive H: appears as the other external drive, or internal SSD AND I can easily access this drive and add what I want to it with no problem..BUT.. when I have a file or something that I want to send to it, I click "Send to" and every available drive connected to the computer is an option EXCEPT Drive H (the installed 500 GB HDD).. I have scoured the inet for answers to this issue to no avail.. ANY IDEAS would be appreciated..Just when I had Windows 10 figured out, 11 came along with the new machine and I am at ground zero on many issues..Have a nice day.. Thanks
NamMedevac 70
Reno
Posted: 03/26/23 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Try copy and paste. May work??? I have a Windows 11 Costco Lenovo Idea Pad laptop with 475 SSD drive and thousands of photos with thousands more documents plus 1K downloads, etc and have used only 140 GB plus I have two backup 500GB external drives (light weight) and never have found a need for different partitions on the disks.
Someone will soon give you the correct advice and maybe then tell me how to speed up searches on my external HD drives that are not even close to been full. Good luck.
TenOC
On the road -- Full time
Posted: 03/26/23 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Everything.exe is a VERY good program to search you HD. I have it on Win10. I think it works with Win 11.
I only use "send to" for blueTooth. I use move or copy for all other HD
* This post was edited 03/26/23 06:54pm by TenOC *
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
joebedford
Home for the summer.
Posted: 03/26/23 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
We're getting a new Dell laptop as soon as we get home in 3 weeks.
W11, 500GB SSD.
Is "send to" a new feature of W11? I've always used copy / paste for other W dot X OS'es.
bob_nestor
murphy
Posted: 03/26/23 07:46pm Link  |  Quote  |  Print  |  Notify Moderator
Dumb question, but are you sure the file you're trying to "send" to drive H: isn't already on drive H[emoticon]
DD716TED
Washington State
Posted: 03/26/23 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thought of that..it is not
DD716TED
Washington State
Posted: 03/26/23 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
W11, 500GB SSD.
Not new feature..use it on Win 10 all thr time.. I can copy / past to "H" but drive "H" is the only one not available when using Send To option..
rk911
DuPage County
Posted: 03/26/23 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
found this online. scroll down past the as.
https://www.easeus.com/partition-manager........ves-missing-after-windows-10-update.html
rathe than copy/paste you can also drag/drop files in explorer.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
ralphnjoann
Colorado
Posted: 03/27/23 08:02am Link  |  Quote  |  Print  |  Notify Moderator
The Copy/Paste procedure is a bit tedious when compared to the Copy to Folder/ Move to Folder alternative. These choices don't appear on the context menu, but can be easily added with a registry modification. For information on how to do this, go to the following link:
Copy /Move
The "Copy To" option copies the information to the new location and leaves the original intact, while "Move To" deletes it from the original location.
DD716TED
Washington State
Posted: 03/27/23 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Copy /Move
Thanks for the information..that would work if the new HDD (H[emoticon] would appear as a place to move it to..but the drive (H[emoticon] does not appear as an option..all other USB drives do appear but not installed (H[emoticon].. H: does appear when looking at Explorer though.. Thanks again as progress is progress...
