RV.Net Open Roads Forum: Technology Corner: Windows 11 Experts?
 > Windows 11 Experts?
j3ff9ack
Idaho/Montana
Posted: 03/27/23 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Not sure why the new drive isn't showing up, but you can add it to the "Send to..." menu.
https://www.pcmag.com/how-to/how-to-customize-the-send-to-menu-in-windows
2007 Jayco JayFlight 27.5 RKS
2014 RAM 3500 SRW CC CTD 68RFE
HTElectrical
Las Vegas
Posted: 03/27/23 11:56am Link  |  Quote  |  Print  |  Notify Moderator
I believe your problem is the "send to" function is for removable drives. Your H drive is connected by a SATA cable or it is a NVME drive, correct? To copy or move information to an internal drive (Sata or NVME) you have to pull up the drive in Explorer, or my computer etc....
Open the drive and then drag and drop, or cut and paste, or copy and paste the information.
2007 Duramax, Cognito 7"-9" Lift,
NamMedevac 70
Reno
Posted: 03/27/23 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious, do you really need an H partition. I have been heavy computing for 30 years and never needed different partitions on my internal or external drives. Thanks.
DD716TED
Washington State
Posted: 03/27/23 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
The new drive installed is labeled "H' and has no partitions.. the external USB 1Gb hard drive has partitions.. but "H" is the entire drive label..
joebedford
Home for the summer.
Posted: 03/27/23 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I put LINUX on a separate partition. I've installed various VMs in separate partitions. My F: drive used to be my C: drive until I replaced C: with an SSD.
Oh yes, I've been computing for 55 years noob [emoticon]
NamMedevac 70
Reno
Posted: 03/28/23 01:55am Link  |  Quote  |  Print  |  Notify Moderator
I see your ego is in overdrive old goat.
Retired financial accountant and commercial plus Army pilot.
https://www.facebook.com/CaptBillPerkinsUNRescuePilot/?pnref=lhc.recent
https://www.facebook.com/william.perkins.79274
* This post was last edited 03/28/23 07:36am by NamMedevac 70 *   View edit history
Fizz
Ottawa, Canada
Posted: 03/28/23 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Didn't take long for this post to blow up.
Typical.
joebedford
Posted: 03/28/23 08:01am Link  |  Quote  |  Print  |  Notify Moderator
OK boomer.
Martyn
Panama City Beach, FL USA
Posted: 03/28/23 08:09am Link  |  Quote  |  Print  |  Notify Moderator
45 years computing here. Recently bought a new Dell Win 11 desktop. 500Gb SSD plus 2Tb factory installed SATA drive. Factory installed and labeled them as C: and H: drives. Now, if I open a file's properties on the C drive, and then select the 'more properties' line at the bottom, I get a 'send to' option among the next set of options. When I select that the H: drive comes up as an available option.
This doesn't answer the OPs question other than to say it should work. Must be an obscure setting somewhere that I, for one, have never come across!
2020 Keystone Cougar Half-Ton 27SGS;
2019 Dodge Ram 2500 QC 4x4 6.4 Hemi BigHorn;
DEMCO Autoslide; 2 Honda EU2000i's;
Our Website
opnspaces
San Diego Ca
Posted: 03/28/23 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
The above is what you are trying to do. But to me there are too many options to make it easy to follow. So try this.
On your computer you need a run command and not just the search box at the bottom of the screen. So
  1. Either press the and hold the windows key on your keyboard and then press the R and the run box will pop up. Alternatively you try right clicking on the little windows icon on the bottom left of the screen and then select RUN
  2. In the Run window type in shell : sendto and press enter. EDIT gotta love our software it keeps adding a smiley in the shell command so I had to add spaces to make it dispaly. That is supposed to be type shell then a colon then sendto with no spaces and no quotes
  3. the Send To window should open
  4. Click and drag that new send to window out of the way but leave it open
  5. Now use file explorer or whatever method you are used to and navigate your drives and find the H drive
  6. Right click on the H drive and select copy
  7. Now go back to the Send To window that you dragged out of the way
  8. In the Send To window pick an blank space and right click and select Paste Shortcut
  9. Wait a few seconds and the H drive will show up
  10. Close the Send To window
  11. Test
* This post was edited 03/28/23 07:02pm by opnspaces *
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
